Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: pics of my 84 t3
    Southern MN
    1,875
    pics of my 84 t3
    Well, I finally got around to getting pics up, thanx to Honda's_better for some help. I bought this trike last Saturday night. As you can see, it needs a LOT of work. The engine runs I know, because I sprayed starting fluid in, and it started on the first kick. It needs a carb, shifter, and clutch to run. The berrings were shot in the rear end, and some parts were welded together, but I finally got most of them off. Since the pic, I have taken out the engine, and re-painted the frame, as well at the swingarm. I bought new bearings yesterday, and also put those into the carrier. It's comeing along slowly but surely. Well, I hope you enjoy the pics. Let me know what you guys think. Thanx.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Southern MN
    1,875
    another..
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Southern MN
    1,875
    You can tell than I dont know how to post multiple pics. oops Here's another.
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Southern MN
    1,875
    Here is one of the engine. Look at that pipe. o It looks really bad, I know. Those are actually wires holding the pipe on in the back. I have no idea what that pipe is off of. I know the seat is off a ks125 kawasaki dirtbike, because I found a little brochure under the seat pan. LOL. Well, enjoy. )
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Cincinnati, OH
    3,289
    wow it looks :shock: anexia (spelled it wroung) lol but im sure it will look better !!!!
    Psyonyde is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2003
    157
    how much did you pay for that beauty?
    1983 Honda 200e
    1984 Honda 200es (needs rebuild)
    1985 Honda 250es
    1986 Honda 250es (parts bike)
    1984 Honda 200es (parts bike)
    Southern MN
    1,875
    A heafty $40. lol you cant go wrong there, huh?
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    May 2002
    Texas
    2,670
    Hey, that's a great price!
    What the hell kind of pipe that is, I have no idea! :shock:
    Some custom drag pipe I guess.
    How 'bout that dirtbike seat!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Southern MN
    1,875
    Your guess is as good as mine Jeb. LOL. It does sound pretty cool tho. I took it off, and am going to buy a stock pipe for it. As far as the seat goes, It latches right on. I hope the guy didnt weld brackets to the frame. How does the stock plastic/seat go on? The previous owner actually tried to weld re-bar to the back of the frame as well. Must have been trying to make a grab bar huh? lol
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Wow...I no longer have the ugliest 84-85 KXT, and you paid $60 less then me. Congrats!
    May 2002
    Texas
    2,670
    The rear plastic bolts on in 4 places under the seat. Then the seat has a latch that fits down through 2 slots in the plastic and latches to the frame. It's better than the 86 I think because the 86 seat bolts to the plastic and then the seat/fender together bolt to the frame. At the same time though it sux because the seat can come off in a wreck, sometimes even from riding hard, and you have to remove the rear plastic to get the cover off the airbox to get to the air filter.
    If that seat thats on it has a latch, it may be working with the stock frame. If it bolts on, he has "customized" it.
    Speaking of the frame, it may just be an illusion from the wrong seat being on the trike, but it looks like it's missing some of the rear frame work. It should come out from under the seat and make a 90 degree curve and each side is welded together. Then there is mounts for the tail light, grab bar, and rear fender support.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    May 2002
    Texas
    2,670
    Another thing if the rear frame has been chopped off is that it might be missing the muffler mounts.
    Anyway here's a pic of a healthy frame. look under the fenders and you can see the tail light & grab bar mountings (that's my stock 86 grab-bar) Also, that's my seat for sale and rims & tires!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    Southern MN
    1,875
    Thanx for the info again jeb. ) Yeah, I think it is missing part of the frame in back. The latches must be the right ones tho, because there are two of them that latch on, as you mentioned. I'm going to have to weld extra mounts or supports on there then, if I want everything to bolt on properly. ? Man, I just keep finding out more and more problems with this thing..
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    not bad for 40$
    YAMAHA'S: 84 225DXL
    04 POLARIS SCRAMBLER 500 4X4
    05 kazuma 50
    May 2002
    Texas
    2,670
    I would almost sell my frame. But I think I'll hang on to it. I may get the notion to go frame up on another one someday. You can probably find one close to you and won't have to mess with shipping. The more I look at old pics of my 84, the more I HATE that I parted off all those nice parts I had.
    Another thing I see your is missing that you might want to round up is the head stay. It bolts to the frame backbone and the boss on the back of the cylinder head.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
