Results 1 to 2 of 2
Thread: Honda 250sx flat carb and back fire
    Jun 2009
    Missouri
    3
    I'm working on getting a 250sx going as a practical machine seeing as my Tri-z is on the fritz. I love it and it's fast but the reliability is a major issue, would you FLY in a Yamaha? hell no, make it a Honda. Anyway, the carb is extremely flat until it gets higher in RPMs and then it keeps reving a second or so after I let of the throttle. I have that damn choke needle hooked up and all but I'm unsure how to tune this problem. Also when it's reving down it back fires out the pipe as well as the carb. Is this valves or is it more of the same carb issue?
    Southern MN
    1,875
    It almost sounds like your rocker arm to valve clearance is too big. i would check the clearance, and if that dosnt help mess with the carb. Did you clean the carb? It may be dirty. The part where you said it revs before returning to idle makes me think your slide could be sticking, or your throttle cable could be routed incorectly, damaged,or needs to be lubed. Spray some wd-40 on the end of the cable so it gets lubed, if you think it looks like it needs lubed. Good luck and to the boards.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
