Thread: 185s automatic decopression assembly
    Miami,Fla.(305)
    808
    can someone kindly tell me how to install the big round spring onto the "hook case"-Yellow plastic ring).- never bother with this mechanism like most, but wanted to get one working just cause i have it in good condition- and easier on the rope & flywheel key. can someone help
    Sep 2007
    100mi west of Chicago
    3,582
    I'm not sure what you mean by a yellow plastic ring, but here is a diagram of the head. The lever installs really easily. Just a seal, washer, spring, and finally the lever. One end of the spring should hook on the little post on the head cover and the other end should hook on the lever. To use it you lift up on the lever.
    Rob
    Miami,Fla.(305)
    808
    my bad, - i'm talking bout inside the pullstart. just the decompression mechanism spring assembly-thanks again.
    Sep 2007
    3,582
    Oh! Duh you said automatic. I don't have any experience with those, but here is the disassemly/assembly: http://www.mediafire.com/?gue2fuzjmww
    Rob
