Results 1 to 15 of 16
Thread: ATC500R exhaust fabrication
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    Fabbing up an exhaust for a frame customer, should be all finished tomorrow and the frame and exhaust parts will get shipped back!
    Fusion weld on the exhaust slip joint. No filler rod.
    OK
    5,450
    Looks awesome as usual..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Feb 2005
    Orchard Colorado
    659
    Bushs Chili Beans, cashews and Pepsi One!!!
    I bet You and your stomach is fun to work with....
    Is your secret out, maybe we've found your inspiration
    '85 Cagiva 200
    '86 Cagiva 500
    '82 ATC 480R
    '83 ATC 250R DG
    '83 Nicholson 185s
    Owned 5 Franks, sold 4, have one left.
    Live Oak, FL
    15,068
    Diet Pepsi! The main fuel of Team Heat & Beat! Other common acquaintances may include, Bush's beans, Cashew nuts, and large cans of Thrifty Maid brand Corned Beef Hash!
    Oct 2007
    Grosse Tete, LA
    3,440
    teach me to weld like that good god....
    also...corned beef hash? that's disgusting.
    Jul 2006
    HEY homie I need a Team H&B tab!
    Aug 2004
    Phoenix
    1,226
    Are there going to be any mounting tabs on the pipe itself?
    4 Strokes are NOT the wave of the future!
    Live Oak, FL
    15,068
    Yup, I made that yesterday. Theres another mount back at the silencer using the single bolt 250R rubber isolator, and then also another one up front that hooks onto a waterpump bolt. Suckers nice and tight when its all bolted down. I was thinking about putting a 3rd one back by the kicker, but it really didn't need it.
    Aug 2004
    Phoenix
    1,226
    I wouldnt have a mounting point off of the water pump bolt. If out riding and the pipe gets dented or wrecked it could cause the water pump/clutch cover to crack. Also the vibration coming from the pipe could do some damage in that area. On the CR500 bikes Honda has a rubber isolation mount that mounts to the downtube then to the pipe. I would try that.
    Masshole
    2,191
    Hey Billy, that looks wayyy better than what ive got! If i ever get back on track to work on my 500, that will be next in line after i finish my kicker assy, i hate the way my mutated 85 cr pipe looks on mine.
    Jul 2006
    hey jeff ask him about my fmf fattty that I still have down there if he wants to give it up you can have it for shipping, it was made for my 500 but then I found that bills pipe for mine, its got a few dents in it but it fit well on my 500
    CUYAHOGA FALLS, OHIO
    1,242
    Quote Originally Posted by 3Razors View Post
    I have to agree on this. Vibration is a killer.
    Pipe looks really nice. Looks like a production Factory pipe. Very nice craftsmanship.
    Im definately going to hit you up on a frame/pipe kit once you get everything worked out.
    Max
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Live Oak, FL
    15,068
    The pipe is mounted everywhere (except where it goes onto the flange itself) with the 250R rubber isolators. I absolutely agree that you can't solid mount the pipe anywhere or it'll tear itself apart, its got to be rubber mounted.
    Masshole
    2,191
    Billy, what exactly did you do to this pipe, cut in 3 places nd twist? Remove any material? I needs a new pipe for mine and thinking of robbing the one off my 94 cr-5 and getting a new one for the bike
    Live Oak, FL
    15,068
    Yup. I didn't remove ANY of the pipe. Mostly just twisting, but there is a small piece about a half inch wide in the middle of it right under the exhaust port (If you look close you can see it) That I had to actually section and flip 180degrees to get the pipe to angle out enough. My best advice is to NOT NOT NOT NOT work on a used pipe. A single dent in it makes it a royal pain in the butt to weld and work with when you twist it around.
    I also had to weld on an entirely new stinger tube from the pipe and around to the silencer.
