what size rear rim fits the honda fatcat
Signature pic removed,becuase of no helmet.
also if someone can send me pictures of the rearend of there honda fatcat,need close ups of the swingarm,
You want rim size and/or tire size? I have my frame, wheels and swingarm all off and up at my dad's house now, so it may be a bit before I can actually look at/take any pics to send. I do have the new rear tire at the house though, and can send you the size if that helps you any.
Jason
check microfiche.....tire dimensions will be here....
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
Custom built ATC70 / 250R laydwon swap
1986 ATC250SX FATCAT
i need rim size and bolt pattern
yeah i tried to put a front rim off a 84 200x just to see if it would fit,it didn't.the fatcat has a larger bolt pattern
Just started my re-build of my Fatcat last night, first of which I put the new tires on the freshly painted rims.....front is a 24x8x11 and the rear is a 23x8x11 as far as the tires go. So the rim size would be 8x11 for each I would guess.
Now the only major parts I have left to "fix" for my rebuild is to get the seat re-done at a local shop, Kreem the gas tank and paint it and re-finish the side panels and that's it. Hopefully by the time the end of August rolls around, I can have it back together. That will be about 1 year of having it apart and part replacing/cleaning/repairing.
Jason in KC
