Results 1 to 15 of 21
Thread: lost spark
    1984ATC200S's Avatar
    1984ATC200S is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    New Brunswick Canada
    222
    lost spark
    I no its been covered, but Ive tryd everything and cant get spark on my 200S, coil, CDI, spark plug wire, boot, 5 plugs that started my BR, my next step is the spark advance, then into the stator, another common problems that cause loss of spark?
    1984 200s
    1984 big red
    1980 Kawasaki Invader 340 liquid
    1993 GMC sierra, 4.3L automatic
    1990 Chev Scottsdale -parts
    1989 Chev wrangler 4.3L 5 speed- parts
    Chevs are for parts GMC's are for driving
    Oct 2008
    NB, Canada
    852
    If you have a multi-meter I'd check to see if the resistance is in spec for the stator and pulse generator. I'd also check, if you haven't already, the wires going to the kill switch to make sure they haven't shorted out to each other or a ground.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Apr 2006
    Crestview, Florida
    2,429
    Most common would be the stator
    Rides
    85 ATC350X
    85 ATC200X
    Dec 2002
    deer park, texas
    2,336
    stator...... But i would definatley check the kill switch. it always seems to be the most obvious
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Oct 2008
    NB, Canada
    852
    Have you got a manual? I've got one, and a multi-meter, so I could give you a hand if you can't figure it out.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    May 2008
    222
    i got the Manuel, 2 actually, and a muilti meter, haven't got a chance to look at it today, probably this weekend, i believe i will go over the kill switch wiring better, i do have a couple butt connectors that could be giving me trouble now that i think about it. does the stator just go or are there signs leading up to it going?
    1984 200s
    1984 big red
    Sep 2007
    100mi west of Chicago
    3,582
    Kill switch and bad ground for the coil are a couple I have seen that cause no spark.
    Rob
    Michigan
    1,144
    I had the same problem on an 84 200s. A very weak spark. Talked to a couple of people about what the problem was. Both knowledge people told me it was probably the exciter coil in the stator. Replace it and 3 or 4 pulls on the recoil and it started.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    May 2008
    222
    Quote Originally Posted by hublake View Post
    as much as i hate to believe, the exciter coil sounds like my problem is there a special flywheel puller for the S style flywheel, like the ski-doo clutch thread in type, or just a three arm puller? and can u bench test them before putting on back in, i have 2 or 3 185/200S engines that have stators i could use, i will read up in the Manuel as well, just don't have it here at the moment.
    1984 200s
    1984 big red
    Michigan
    1,144
    I bought a puller from my Honda dealer. It was only about $12.00 and fits a number of Hondas. I got information from a board member here and he said that when you check the resistance of the exciter coil that is in there and the reading is below 200 ohms it is probably bad. I was told the reading should be between 215 and 240. When I checked mine I was around 190 and when I put the new one in it was around 230. You can check it by putting one probe in the black wire that comes from the stator and the other probe just get a good ground on the case. If you have a puller it is a simple job. You just have to solder the black wire to the coil.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    May 2008
    222
    If i do change it I'm going put on the whole stator form my other engines, so all i need is the puller, and some time. I'll check over everything this weekend and order the puller next week, if i don't find anything else first.
    1984 200s
    1984 big red
    Oct 2008
    NB, Canada
    852
    Maybe its different on a 200s, but on the 200e motor I have, the stator is on the outside of the flywheel, so the flywheel dosen't have to come off to get to the stator.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    May 2008
    222
    Quote Originally Posted by Gearheadtom View Post
    where the 200S/185's are pull start only, the flywheel/stator is different, i wish it was as easy as the BR's and the M's to get to it, but once i get the puller it should be an easy job to do. we gotta get for a ride this summer, worse thing is it seems like the cops around here are getting thick.
    1984 200s
    1984 big red
    Oct 2008
    NB, Canada
    852
    Quote Originally Posted by 1984ATC200S View Post
    The cops are getting thick, thats what 5th is for . Before we get out for a ride, I'd like to try and get a new helmet, you would laugh to much at the one I have now.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    May 2008
    222
    haha, they have a habit of pulling up when were stopped, but im all legal, as far as a helmet, as long as it does its job it don't matter what it looks like.
    1984 200s
    1984 big red
