im gonna be getting a dg xccelerator for my 350x soon and was told i should get jets, i only know that jets go in the carberator, thats it. when i go and order the pipe and the jets is there a certain size or kind ill need?
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
c'mon guys help me out
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
I'm still figuring mine out. I've got a 200es that I put a new cobra pipe on and it ran pretty hot right after I did that. I decided to upsize the jet and go from there because I figured it was better to start rich than lean. You will probably find that with the new pipe, your trike will run hotter than it did. I prefer not to let that happen so I changed the main jet and adjusted the carb from there. To find your stock size, just call any honda dealership and ask them.
I'm sorry I forgot. If you have never taken a carb apart, go to bikebandit.com and follow the prompts for oem parts. You with me?--then look up your year 350x and find the carb. This will give you a detailed and labeled view of your carb before you tear into it. (and I was talking about your MAIN JET)
Install the pipe, run it and read your plug. It will tell you if your jetting is correct.
