Results 1 to 3 of 3
Thread: Removing oil pump 87 LT80
    OK
    5,450
    I'm removing the oil pump on my 87 LT80, it is leaking oil into the carb and gooping it up. I have to remove the left hand case and remove the black plastic gear that turns the oil pump. My question is if the left hand side of the motor has tranny oil in it or not? How much? and what kind? You are right.. I do need a manual.. and I'm working on that. If you know. help a brother out. The airbox inlet off the carb had a hole in it. I'm replacing that the reeds and the gaskets. I've cleaned the carb.. going to remove the pump and mix it myself at 32:1.
    Thanks,
    Doug
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    there is someone over at atvconnection.com that goes by the name LT80 and he knows his stuff on em.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    OK
    5,450
    I've been on over there and know what to do to remove it. I just didn't know about the fluid. MonroeMike sent me a manual pdf, so I got that figured out.
    Once again, Thanks for the help guys.
    Doug
    Quote Originally Posted by 1985BigRed250ES View Post
    Rides:
    My feedback thread
