Results 1 to 15 of 18
Thread: Annoying tri moto 175 problem. Rear axle and chain adjuster...
    May 2008
    Blackstock, Ontario, Canada
    89
    Question Annoying tri moto 175 problem. Rear axle and chain adjuster...
    Has anybody had a problem with the rear axle on the 175's? My chain keeps getting massive amounts of slack and then flying off. The chain tightener/adjuster is "screwed out" all the way, but I can still move the axle back further by hand.
    Basically, the chain is always loose and the adjuster does not push the axle back far enough. This is such a stupid problem. Ill try and get pics tomorrow.
    Nov 2008
    Coon Rapids, MN
    956
    I just had that same problem about a week ago and it turn out that my sprockets and chain were so worn out that the adjuster would not tighten them anymore, I replaced the chain and sprockets and the adjuster tighten the chain no problem.
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Monroe MI
    5,787
    Is it the correct length chain? Stock is 48 links.
    May 2008
    89
    The thing is the sprockets look quite decent still. The only thing I don't want to happen is to get a new chain and sprockets and then find out I still have the problem. I'm pretty sure the chain is 48 links, but I'll check later today, and try to get pics.
    Thanks guys.
    May 2008
    89
    Got some pics showing the gap between the adjuster and the axle. I took one of one of the bolts showing the axle can come back even further. I think somethings wrong here? Are pieces missing from the axle carrier or something?
    Attached Thumbnails Attached Thumbnails dc1040 003.jpg   dc1040 006.jpg   dc1040 007.jpg   dc1040 008.jpg
    Mar 2008
    Stockholm/Sweden
    64
    I had the same problem, and found that the sprocket looked ok, so after the chain was replaced, problem was solved
    *1985 Yamaha Tri-z 360 big bore Ohlins with powervalves, 38-carb, boyesen reeds and pro-circuit exhaust!
    *1985 Honda ATC 350x "stock"
    *1981 Yamaha Tri-moto 175 "stock"
    *1982 Yamaha rz350 with Jolly-moto exhaust
    *2004 Kawasaki sixdirtysix Stuntbike
    *1987 Pontiac Trans-Am
    *1996 Pick-Up
    May 2008
    89
    Guess I'll have to look into a new chain. But shouldn't the adjuster move the axle back even further? Theres still a lot of room for it to do so.
    Pa.'s Highest City
    8,058
    is there play in the rear axle? 20+ year old bearings should probably be replaced anyways.
    Baltimore, MD
    6,088
    It's tough to tell when the trike is so dirty! Who knows if the bolts are original or not. Maybe they are not the right length. Have you looked anywhere to try and see if pieces are missing? Maybe compare what you have to microfiche pictures? Here is the other thing that I haven't heard you mention one bit, does your trike have it's spring loaded chain tensioner? They had one you know. If you're trike doesn't have the spring loaded chain tensioner foot, then that could be your problem. Also there should be 2 bolts on both sides of the rear bearing carrier. One is what I would call the pivot bolt and the other bolt you loosen so the carrier moves back and forth in an arc so help provide chain tensioning. These bolts should be tight once you have your chain tension set. It all works together to give you the proper chain tension or adjustment. I have not heard you mention this either.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    leokendall is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    corner brook, Newfoundland, Canada
    180
    lol take your chain off and remove a link.
    1984 Honda Big Red
    Mar 2008
    Stockholm/Sweden
    64
    Quote Originally Posted by leokendall View Post
    Hahaha, I tried that and then the chain was to tight!!
    *1996 Pick-Up
    May 2008
    89
    It looks to have stock-looking bolts, except one (pictured) which is a nut. Also, the lower left bolt is stripped, it just turn both ways without backing out or screwing in. I'm not total sure about missing parts... I'm pretty sure its not missing stuff. I've looked at various diagrams, and it looks all there.
    Now, the trike does NOT have the chain tensioner... not to sure where it bolts on either becasue there doesn't look like there is a lot of space because the chain is so short.
    Nov 2008
    Coon Rapids, MN
    956
    I don't have a spring loaded tensioner on mine ether all I got is a plastic wear block in the plastic cover and it only rides on that when the chain gets loose. I looked in all my microfiche I did not see any spring loaded tensioner for the 175 so I am a little confused. I tried to upload the PDF files but they are to big so it won't let me.
    Alex
    My feedback.
    My album
    May 2008
    89
    Quote Originally Posted by old-yellow View Post
    Alex
    Same with me. I remember looking on bikebandit and also in the manual I have, and I don't recall seeing anything missing, like a tensioner. But if someone has one for cheap that I can make sure fits I'm interested.
    ugghh these yamaha trikes are so confusing
    Baltimore, MD
    6,088
    I don't think it is a spring loaded tensioner, but on some of the trikes there is sort of a small fiber sprocket and on some there is what looks like a small fiber foot piece, but it is not on the chain guard. Then there is alwyas aftermarket. Ever seen one of these before? Aftermarket yt125/175 chain tensioner made by Pro Tec.
    Nicholson 185s
