Thread: ATC70 oil leak
    Apr 2008
    Vernal,MS
    47
    ATC70 oil leak
    I just overhauled the top end of my '85 ATC70 and when I cranked it up, oil was pouring out by one of the head bolts. I torqued all the nuts down and have all new gaskets. I can not figure what's up with the oil bypassing the lower left bolt. Any help ?
    Race Demon is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2009
    coshocton
    245
    sitting on the bike, the lower right should have a brass washer for a seal on it , I think thats what your talking about
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    If Its On The Top ,, Yep The Brass Washer,,, If Its In The Gap Between The Head And Cylinder,,, The Oring In The Head Gasket Is Missing...
    Apr 2008
    Vernal,MS
    47
    That's the correct bolt leaking. Problem is, I have not noticed any difference in the washers. I'll double check that brass washer. 3 nuts are cap-types and 1 is a regular hex head. I suppose that the one that should have the brass washer?
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by Hayward View Post
    Mine has cap nuts on all four head studs.
    Appalachian American Racing
    the home of
    Apr 2008
    Vernal,MS
    47
    Thanks you All ! While bolting the valve/rocker cover on, I got the bright idea to add lock washers.?> ?. After looking for the brass washer you mentioned, it hit me what the problem was. After removing the lock washers, no leak problem. Thanks again and have a fun and safe ride ...
