Results 1 to 13 of 13
Thread: 1986 tecate overheating
    Sep 2006
    N.S. canada
    499
    hey guys as soon as i start my bike and let it run for 30 seconds my coolant pours out the over flow and i can hear it boiling in the radiator. the right side if that makes a difference. i just need to be pointed in the right direction thanks
    86-tecate
    Jan 2005
    RI
    2,530
    sounds like a head gasket leak to me.
    it isnt running long enough to boil, you're hearing air being pushed into the coolant system.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Sep 2006
    N.S. canada
    499
    thxs for your reply but it is a new head gasket but yeah i was thinking it was the head gasket is there anyway i could buy a stronger one?
    86-tecate
    Apr 2004
    Brigham, Québec, Canada
    1,528
    The head or jug are probably warped. Take the head to a machine shop, they will be able to tell you if it straight.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Sep 2006
    N.S. canada
    499
    ok so i tryed it out again today without the rad cap and it worked fine what would that mean? and i have coolant in my base ...... wud that be a cracked cylinder?
    86-tecate
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Well How is your compression? Do you have a compression tester? I had the same problem with my head gaskets for the longest time. planed head/cylinder and still it does it. So I used what I have used in the past. A small amount of jb weld around the outside of the metal ring. Never blew one yet. I wont even waist my time. Also your head nuts might be loose. Re tourke them. might help. 35-40$ top end kits are expensive after a while.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Sep 2006
    N.S. canada
    499
    my compression is 250 psi and i always retork after every ride
    86-tecate
    devore,ca
    1,042
    WOW, 250 psi?
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    shadix518's Avatar
    shadix518 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2009
    Wichita, Kansas
    198
    do those bikes have a thermostat? sounds like a stuck thermostat to me but i havent had the opertunity to work on a tecate yet
    1985 Atc 250sx my first.....
    1985 Tri-Moto 200......SOLD
    1985 Yamaha 225dx.....
    Sep 2006
    N.S. canada
    499
    yea 250 psi do you guys use the three kick rule or just stop kicking when the needle stops on the comperssion tester? and it doesnt have a thermostat
    86-tecate
    Mar 2005
    overton, PA
    5,257
    wow my drag r is only 220 psi and thats set up for race gas
    Sep 2006
    N.S. canada
    499
    yea i need to get race gas i donno where im getting 250 from
    86-tecate
    Nov 2002
    1,838
    i kick with throttle wfo till needle stops. 210 for me. Though of using race gas. Can you mix gas with race gas to raise octane levels?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
