I've kicked this idea around for a while now but keep getting hung up on the chain adjuster. The logical choice would be to go with an eccentric cam style rear end that most performance oriented ATVs use but cost starts to become an issue when you start adding up all the bits and pieces.
I have most of the pieces I'd need to pull of this kind of build. I've got a set of CT70 forks, CRF70 frame and gas tank, and an 85' ATC 70 that I wouldn't mind hacking up for the build. I'm thinking that the full rear end out of a TRX250X or TRX 300EX would probably be the best bet. There is no shock linkage, and it's shorter and narrower than the majority of what's out there.
83' ATC70
85' ATC70
83' ATC200x
96' TRX90
05' CRF50- The only thing left that hasn't been modded out are the engine cases.
