Hey guys what do I need to order to fix a oil leak that is dripping from the shifter on a 86 model. It had never dripped before and now all of a sudden is getting bad. Any help is appreciated and thanks in advance.
You can check out Dennis Kirk.http://www.denniskirk.com/jsp/tpl/cm...d=11512&page=3 Whole seal kit. $70.00 Make sure all the seals are there..Dennis Kirk Part #: 262352
Manufacturer Part #: 811814.. for 86 250R
80' Honda CR80R
78' Honda XR75
77' Honda CT-70
74' Honda CT-70
75' Yamaha GT80 Enduro
76' Kawasaki KZ900
73' Kawasaki H1-500
76' Kawasaki H1-500
You can change it by screwing a screw into it and prying it out.
That seal gets dirty from chain gunk. Sometimes I've been able to wipe the inside lip with a pin and a very light cloth as it can be just dirt stopping the seal from sealing. It's a patch at best anyhow.....
Thanks for the info guys. I just put a new stator in it and thought I was up and running for a bit and now oil on the floor. Is there a name for this seal you think? I thought it maybe could be purchased seperate from the complete set but I am not for sure. Many thanks for the help.
just called the shifter seal, they are cheap and very easy to replace. like dirt said just screw in a screw and yank it out with some pliers. make sure you drain the oil first or else you will make a mess lol.. then using a deep well socket gently tap in the new seal, making sure you clean the area firstof all debri
the dealer has those cheap
"Advice is Free, The Right Answer will cost you"
Thanks again guys, I cleaned it up this weekend, and that fixed it. I will be ordering a new one to be on the safe side. Thanks
