Thread: 86 250sx swingarm help
    i need help getting the nut off the swingarm bolt. i tried lubes and everything is there a special tool b/c im only using a screwdriver and .
    There is a special tool however I use a metal drift (looks almost like a chisel but has a round flat end) and .
    Re: 86 250sx swingarm help
    Quote Originally Posted by 250sxRacer
    I'll bet the tool is useless due to corrosion being in there. I use a 2lb and a 5/16 diameter pin punch with a nice 90 degree end on it. One or two good whack loosens it up just fine. Then I ue a 17mm bolt with a nut welded on it to remove the pivot bolt. Just did 4 SX swingarms and bearings and seals with grease fittings. Got all of them apart except one which I used a little heat and spray and whack and heat and spray and whack and whack and ......it came loose too. Make sure you torque that pivot bolt just as the manual says or you'll come loose. I still have 2 sets of bearings but noone seems to like half price . Good luck with the SX!
    May 2003
    140
    250sx
    when I can't get rusty stuff off I use PB blaster it's the best stuff .I use to try with wd40 what a joke that was.
    Ashland City, TN
    2,576
    Re: 250sx
    Quote Originally Posted by John mendolera
    AMEN to that brother!
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
