kawasaki klt160 question
Can anyone tell me if the carburetors on a klt160 and klt110 are the same? if not does any bike share the same carburetor as the 160? I'm tring to find a rebuild kit for it.
thanks
No, they're not the same. the klt110 is an 18mm, and the klt 160 is a 22mm. The 160's carb is a Keihin VM22SS. you might be able to find a rebuild kit by using the part number instead of the trike for reference
The manual shows the KLT110 has a Keihin PC18.
The KLT160, KLT185 and the KLF185, all use a Mikuni VM22SS.
The main jet for the 160 is #110, the 185's are #100.
The 160 and 185 pilot jets are the same (#22.5).
thanks. i appreciate the info
//ArrowChat Integreation Code
