hello im new but i have a 84 honda 200es that i put a new head gasket on and it wouldnt start. So i let it sit and now i would like to lnow how 2 fix it.
first off welcome to the site...
now... lets begin
did it run prior to the head gasket being put on?
is the timming correct?
is there spark
is there gas?
does it feel like it has compresion?
we need more infor to help you get it going for all I know the flux capacitor could be out or just as simple as a muffler bearin change.
I think the timing is correct but im not sure if the cam or the crankshaft needs turned 180 degrees.as fotr the other yes it gets gas,sparkand yes it has compression
and yes it ran awesome before the headgasket blew and I had to replace it.
cam lobs pointing down, t on the flywheel lines up with the notch on the cam. the f on the flywheel lines up with the plusar?
1984 Honda Big Red
valves adjusted
1984 Honda Big Red
no they are pointing up
Im going to say its the the thing on the side of the head turn it 180 that was the awful problem i ran into when i rebuilt my 83 200e i did have spark if i remember right but it wouldnt do nothing but turn over. tryied going to my local motorcycle shop and was told they wont look at old 3 wheelers but i figured it out eventualy.
05 Kingquad 70085 200x
85 250es
85 350x
85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
