ok guys and gals. i know, another jetting question. here goes.
i have an 84 250r bored to 71.50 and i have a pj34 carb. i am currently running a 48 pilot jet and a 165 main (i now main will to big but i wanted to go rich from the start)
i am starting to dial in my idle to start things off. i am following the duncan racing's jetting information. i have the trike idling pretty darn good,my air screw is out like 1 1/8th turns . but here is my problem. when i blib the throttle, the rpm's hang up there for a bit, like 10-15 seconds or longer if i hold the throttle open more.
i have pressure tested my engine several times. and there is no leaks. could my main be causing this problem, or my needle height ?
thanks, and any information would be great,
