Results 1 to 15 of 23
Thread: ATC Gun Rack
    Nov 2008
    New York
    117
    ATC Gun Rack
    anyone have any improvised gun racks for there trikes....I have a 250sx and would like something to hold my rifle.....I don't have a rear rack nor do I plan to put one on it....
    1985 Honda 250sx
    1989 Wetbike
    1998 Skidoo Formula Z 670
    1986 Monte Carlo SS
    1999 2 Door Tahoe
    Nov 2008
    New York
    117
    Maybe something that goes down the forks....Any pictures of your setups would be great
    1985 Honda 250sx
    1989 Wetbike
    1986 Monte Carlo SS
    1999 2 Door Tahoe
    Dec 2002
    deer park, texas
    2,336
    I have owned two with gun racks. one was a 200m and the other was a yt175. they were just an universal type rack that mounted to the forks. let me see if i can find a pic.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Nov 2008
    New York
    117
    That would be perfect....any idea where to get something like that...I am having a hard time finding it
    1985 Honda 250sx
    1989 Wetbike
    1986 Monte Carlo SS
    1999 2 Door Tahoe
    Dec 2002
    deer park, texas
    2,336
    http://www.3wheelerworldforums.com/s...ighlight=yt175
    I have a pic of the 175 on this thread. You can kinda see it a bit. If i remember correctly it was just an academy atv gun rack that he welded a metal plate onto it. Bolted to the bars.
    Nov 2008
    New York
    117
    that would def work....I once saw a big red with a hard case that wend down the fork tube....I would love to do something like that...was wondering if anyone had something like that
    1985 Honda 250sx
    1989 Wetbike
    1986 Monte Carlo SS
    1999 2 Door Tahoe
    Nov 2008
    New York
    117
    Anyone else
    1985 Honda 250sx
    1989 Wetbike
    1986 Monte Carlo SS
    1999 2 Door Tahoe
    Jun 2003
    Anchorage/Homer, Alaska
    480
    Quote Originally Posted by montess85 View Post
    That's what I want to do.
    My rear rack fills up with gear pretty fast for a weekend trip; strapping my 12 gauge to the gear does me no good if a bear/zombie/whatever shows up quickly. I don't want to mount it to the very back of the rack; I don't want to turn to get the shotgun and my tires throw a whole lot of mud on everything back there. I don't think I want to go across the handlebars; I lean and pull the handlebars from all directions, and I don't want the extra weight up there. I also tried along side the machine and up a rear fender, but it got in the way of my leg and wasn't an easy draw.
    I need something that will protect the shotgun from water, impact, and still provide an easy draw. I think I could make my own case/sheath out of steel tubing. A small tube for the barrel; a larger piece for the receiver and stock. (my stock folds over the top of the receiver) Maybe flat steel with tube on each side to make an oval shape. I'd make it as small as possible, just big enough to fit my shotgun. I'd mount some rubber pieces inside to cradle the shotgun. Only the buttstock end would be open; when mounted down the right hand fork it would be easy to draw. Remember on the SX that you won't be able to mount anything below the lower triple. Since I am making my own front rack also, I will use that as a mounting point with another mount off the handlebars for extra support. I plan on having it mounted with just the pistol grip above the level of the handlebars. With my short shotgun it shouldn't hang below the front axle. To keep dirt, water and the elements out, I can put a flange around the top that will hold a fabric (marine grade vinyl probably) cover with elastic on the lower edge. A drain hole with plug on the bottom of the case would be a good addition too.
    I have to decide if I'm going to put a tactical light on the shotgun before I do all this work. Y'know, for bears!
    I'm still a few months from working on this; I'm eager to see what you came up with!
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    May 2009
    Brampton, ontario
    686
    i say install chain gun turrets to you handlebars.. make your whole trike a wepon!!
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    Jun 2003
    480
    I have an M240H assigned to me right now. I think it would have an effect on the steering!
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Mar 2007
    Texas
    5,045
    my 82 BR came with a gunrack that mounted to the strut top bolts where the handle bars mount botls to the struts on top. (sorta like a "Tree"). i will never use it. you can have it. it looks like a home brewed one.
    ________________
    https://www.mikesatvfix.com
    Oct 2007
    Grosse Tete, LA
    3,440
    check the catalog at j&m atv
    I seem to remember them having that.
    If they do, pm me, I can order you one.
    Nov 2008
    New York
    117
    I wish I could find a picture of that big red
    1985 Honda 250sx
    1989 Wetbike
    1986 Monte Carlo SS
    1999 2 Door Tahoe
    Nov 2008
    New York
    117
    The rack that I saw looked like one of those hard case Koplin ones the in was mounted verticaly on the left fork tube....
    1985 Honda 250sx
    1989 Wetbike
    1986 Monte Carlo SS
    1999 2 Door Tahoe
    Jun 2003
    480
    Google Images led me to this one...
    It's sorta like what I want to make. I want mine to be slimmer, higher off the ground and have a whole lot less fabric up top.
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
