I have a stupid queston but what is the purpose of jetting is it for higher alltitudes or does it increase performence
My Trike is a Mut but once was a 83 Ytm-200
Jetting makes it run at the correct air/fuel mixture. Jetted to rich, your engine will bog, running lean makes the engine run hot and risk burning a hole in the piston. If your getting right you should have quick throttle response and the engine will run like a champ!(Providing you have a good top end)
Trikes:
1973 Honda ATC70-orange!
(2)1985 ATC70
1985 Big Red 250
1985 250R
