Thread: 185s carb trouble
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    185s carb trouble
    My 81 185s is smoking from getting to much fuel and fouling the plug. The needle is set on the second position from top and pilot screw turned out two turns. I moved the needle to the first notch and left pilot screw alone and now it runs to lean and dont run right. What else should I try to do to it?
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    May 2009
    Wingo, Ky
    278
    Well I put the needle back on the second notch and screwed the pilot screw all the way in then backed it out 4 turns. Plug looks alot better now. Its a brown/grayish color. Before it was solid black.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
    Apr 2006
    SE CA Dez in the sandbox
    894
    Initial Pilot screw setting is 2 full turns out.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    May 2009
    Wingo, Ky
    278
    I mess with the carb some more today. Runs way to rich on 2 turns. I got it out to five or six turns and still a little rich. Needle is set on second notch if I move it to top notch runs to lean. I guess it needs a good cleaning or a new carb.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
