Thread: auto X ?
    Oct 2008
    Iowa
    51
    auto X ?
    will a 84 200E with the high low gear box fit into the 84 200X frame or is the gearbox selector on the side to big?
    Nothing better than a blonde and a trike
    My feedback link http://www.3wheelerworldforums.com/s...ad.php?t=95074
    click here to leave feed back
    Current Trikes
    84 200 Auto X
    85 250SX
    84 200ES Big Red (Franken Trike)
    85 Yamaha 225 DR
    85 Yamaha 225 DX
    85 250ES Big Red
    85 200X parts trike
    85 185 Auto X
    Apr 2004
    Brigham, Québec, Canada
    1,528
    82-83 200E or 84 200ES, because there is no way the 84 200es engine will fit in the 200x frame. But I'm not sure for the 82-83 200E.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Oct 2008
    Iowa
    51
    the 200E
    I know the 200ES won't because it is shaft drive but the 200E has the high low lever on the side and I am not sure if it will clear the 200X frame but I don't want to buy the motor if I can't use it
    Current Trikes
    84 200 Auto X
    85 250SX
    85 Yamaha 225 DR
    85 Yamaha 225 DX
    85 250ES Big Red
    85 200X parts trike
    85 185 Auto X
    Oct 2008
    Iowa
    51
    just to make things clear I am refering to the honda 200E not a yamaha
    Current Trikes
    84 200 Auto X
    85 250SX
    85 Yamaha 225 DR
    85 Yamaha 225 DX
    85 250ES Big Red
    85 200X parts trike
    85 185 Auto X
    Southern MN
    1,875
    The 200e will be a challenge, because of the electric starter. It would be 10 times easier to run the simple 185/200s engine, because they allow a lot more room. However, I HAVE seen a guy put the 200e motor in a 200x chassis, but he didnt have the front motor mounts quite right, and they would definatly need some sort of modification (using 200x mounts). The 200e motor seemed to almost sit crooked in the front, because the starter touches the frame. If it were me, I would recomend the 185/200s motor, because they come a dime a dozen, and are just that much easier.
    By the way, did you ever get that DX together? Take it easy, Jon.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
