Thread: Uni Air Filter
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    Uni Air Filter
    In a previous post I said my 81 185s was running a little rich. It has the stock air cleaner on it and needs a new one. I heard good things about the Uni filter and figure it will help it to run a little leaner since this filter flows better? Do they fit into the stock air box? I seen some on ebay for about 20 bucks plus shipping. This would be a good upgrade over the stock filter?
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    Sep 2007
    100mi west of Chicago
    3,582
    Yeah they fit where the stock filter would and would lean it out if you are running rich. You may still have to monkey with the jetting to get it just right though.
    Rob
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    UNI is the best filter you can buy, and it doesnt fall apart when you wash it in gas to get the filter oil out of it.
    May 2009
    Wingo, Ky
    278
    Cobra Exhaust
    I guess since I am going to make my 185s be able to breath in better I need it to also flow out better. I've been looking at the Cobra exhaust systems from Dennis-Kirk. Would this be a good upgrade? The engine has lots of compression, cant start it without using compression release. But when I rev it up and put my hand over exhaust it dont seem like anything is getting out the way it should. Its factory exhaust right now. Is the Cobra exhaust system loud? Thanks in advance.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
    Jun 2009
    Hutchinson Kansas
    123
    my 200x with cobra pipe is fairly loud, not the loudest, but fairly loud.
    OK
    5,450
    Check out Ebay as well for deals on old school pipes.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
