yz 85 crank sticking
ok i have been helping the neibor kid with his yz85 it set for a few months his dad had him runing it with 50;1 mix (i still argue this is way to rich ?) and then was ran hard for a couple hrs and then it sorta locked up he had me looking at it and i messed with the crank for about 20 mins and got some dirty grime out of the rod bearing then it started moveing with just a couple sticks in it so i got some motor oil and put a bit on it and it freed up fine and has no sticky spots and turns like a new one it has no up or down play and just a wiggle side to side everthing else is fine should it be runable?
also the kids dad thinks he knows everything about a 2 stroke but i had to bring my flywheel puller over becuse he was gona tryin pry it off.
i convinced him to just let me reasemble the motor the cases r back togther now with the crank and it seems fine
3 wheelers
1983 200x flat tracker
1983 200x almost original
1983 200e bigred parting out
let me know what parts you need
