You need to lower those fork legs down in the triples some, you won't like that handling at all the way they are. Also, you need to vent the upper valve cover and then run that vent line back to you vented dipstick and have a "T" to tie them together to vent all that turbulent air in the head and engine case. If not, you could start having alot of oil leaking past your gaskets and seals. Also, where is your deadmans' switch? Any good racer needs a deadmans' switch. If you're flattracking, you need to lower those trikes down some also with some lower profile rubber. Those are sweet machines though. I bet we could chew the fat for hours over some building techniques.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
