The oil change shouldn't have mattered, I guess the 200M is a dry ignition?
So no oil on the left side (aside from Mr' Drip
) Is a 200E a pull start?
I can't see 5W30 ruining seals, sounds silly........ Of course some people run thicker oil to solve many problems, so who knows.....
I've seen guys mix gear oil and 10/40 to try and solve a worn ring issue
They are probably just old and dry and need to be changed.
IDK about that model, some you can change without splitting the case.
