Results 1 to 11 of 11
Thread: 86 200x making noises
    Ohio
    593
    I just got all my parts together and started her up, it making a noise like metal hitting metal, kinda in rocker box. the rockers are grooved pretty bad i guess, the left one wouldn't adjust, it went all the way counterclockwise but i did do the right one right I'm pretty sure. timing is right on. It starts up fine otherwise.
    The cam chain is loose a bit, i have a new one but I have to go buy a socket. I tore it down again and inspect the vavles and piston and i don't see any marks or anything. no other damage i can see but the noise is as loud as the stock motor.
    it's smoking too, but i think it's just oil in the parts. rings look new, but im not sure.
    Apr 2006
    Crestview, Florida
    2,429
    are you sure you turned the rocker adjustment the right direction? One goes one way and the other goes the other way. Anyway you look at it, it sounds like you answered your own question.
    Rides
    85 ATC350X
    85 ATC200X
    Ohio
    593
    oh really? hmm i did not know that
    Toledo, Ohio
    103
    From the '86 Service Manual
    1)Loosen the valve adjuster lock bolts fully.
    2)Move the intake AND exhaust valve adjusters counterclockwise fully, until resistance is felt.
    3)Then move them BOTH clockwise the equivalent of 1/2 graduation (.003).
    4)Tighten the adjuster lock bolts (making sure the adjusters do not move).
    Apr 2006
    Crestview, Florida
    2,429
    I guess im mistaken, anyway if you say it moves all the way without resistance, you have a problem there.
    Rides
    85 ATC350X
    85 ATC200X
    Ohio
    593
    yeah the exhaust one goes all the way to the left with is counterclockwise, the right firms ups and is adjusted right.
    I'm buying new rockers on monday, hopefully that's all i need.
    Your probably gonna have to change the timing chain and guides.
    If those shafts the rockers ride on are scored at all, they'll ruin the new rocker arms....
    Did you measure up the cam too??
    Ohio
    593
    I have a new timing chain, and I'm going to put it on as soon as it's a runner. the shafts look fine to me, and the cam, i have nothing to measure it.
    You may not have the cash, but the chain is a quick fix without replacing the 2 guides..... It REALLY quiets these old motors down :
    Ohio
    593
    well I'm going to put the new timing chain on when my rockers come..and i'm taking some pics right now
    Ohio
    593
    http://s32.photobucket.com/albums/d4...=IMAGE_040.jpg
    http://s32.photobucket.com/albums/d4...t=PICT0069.jpg
    http://s32.photobucket.com/albums/d4...t=PICT0070.jpg
    http://s32.photobucket.com/albums/d4...t=PICT0071.jpg
    http://s32.photobucket.com/albums/d4...t=PICT0072.jpg
    Sorry I'm not so good at picture taking on no batteries haha. took a pic then it shutted off and i had to rearrange the batteries. I also can't figure the pics out..I forgot how to make them work.
    What do you think?
