Results 1 to 14 of 14
Thread: Tri-moto wont go
    Mar 2011
    haliburton
    43
    Tri-moto wont go
    I pulled my tri-moto out this year and put fresh gas and fresh oil in it and noe it will idle fine but as soon as I give it gas it bogs and dies.I cleaned the carb and it went but as soon as I stoped and tried to go again it will bog right out.Anyone ever had the same problem or know whats wrong?
    Jan 2011
    Avon, Minnesota
    641
    running lean because of clogged jet or airloeak
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Mar 2011
    haliburton
    43
    Where should I look for the air leak?
    Nov 2010
    Oshawa, On, Canada
    2,123
    While its idling spray crab cleaner around the carb, and intake, if it changes the rpm's you found your leak...
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jan 2011
    Avon, Minnesota
    641
    around where the carb mounts to the boot, check the boot for cracks, then where the boot connects to the motor. how did you clean the carb?
    Mar 2011
    haliburton
    43
    Took carb off,took both jets out sprayed carb cleaner then air till I could see through them,cleaned bowl,put back together.It almost sounds like its getting to much gas.I dont really wanna mess with the air jet cause it ran so good last year.Carb boot looked fine.I will try spray in the morning but if anyone can think of anything elses let me know.
    Thanks Guys PINHEADED
    Afrothunderkat's Avatar
    Afrothunderkat is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    Richmond NH
    336
    SELL IT. Thats what i did with mine.
    2003 RM 250 ::: 1985 ATC 250R ::: 1986 ATC 250ES
    Past Trikes: 1985 YTM 225DX ::: 1984 200s ::: 1985 YTM200
    Past Bikes: 1987 KX80BW ::: 2002 TT-R 125L ::: 2000 RM 125
    Quote Originally Posted by Tri-ZNate View Post
    Talking about the build quality, I got their exhaust and economy muffler and it fits together like tossing a hot dog down a hall way with nothing provided to take up the slop. Best $200 ever spent
    Jan 2011
    Avon, Minnesota
    641
    DONT sell it just because you dont have the patience. if you didnt spray out the back ports from the airbox, and every little crevice DO SO. take out the air needle and everything in the carb. EVERYTHING that screws out un screw it and blow out the carb every hole you see and make sure its clean. triple check if you have to. just because the carb jets are clean doesnt mean the carb body is
    glendive, montana
    1,822
    also check to see if the throttle needle is loose, weird things can happen if it slides up and down on it's own, there is a cir-clip, and a w clip that holds it in place. I would also check the needle for wear or if it is bent mine was bent and I replaced it made a world of difference.
    Mar 2011
    haliburton
    43
    Thanks guys gonna check right now and no i never sell anything with three wheeles!!!!
    9,019
    Did you drain your tank, or just top it off? If the carb is clean you may have water at the bottom of your tank. Make sure your air filter or air tube (in your frame right?) is not home to a family of mice while you're in there.
    Mar 2011
    haliburton
    43
    Found that it is a cracked reed.Any one have a set?
    9,019
    Quote Originally Posted by PINHEADED View Post
    http://www.ebay.com/itm/Boyesen-Powe...sories&vxp=mtr
    Mar 2011
    haliburton
    43
    Awsome thanks
