Results 1 to 15 of 27
Thread: 1985 Honda 200 m atc - no compression
    May 2013
    saskatchewan
    10
    Hey all. New here. Just bought a 1985 atc 200m for the boy on the weekend. Used it for one full, hard day. Snow, water, mud, lots of water. On way home, bike kept dying. Had a bad squeak when fired up. Picked it up with truck. Turns over now. Seems like next to no compression. Has spark but plug not even getting wet. Any help appreciated.
    Sarnia, Ontario, Canada
    3,415
    Sorry Redneck, too man variables..
    You are gonna have to dig into this and get us some basic info.
    You can't just throw it at us and ask us what's wrong with your trike.
    Did it run low on oil? Compression check results?
    Get us some info and we can help..too many new members jump off their trikes and run into the house and go online to ask before checking anything.
    Right now the ball is in your court!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    May 2013
    saskatchewan
    10
    Sorry about that. Just thought someone might have a quick point in the right direction. I am going to start removing the motor today. Oil was and is and is good in machine. Compression tester I borrowed does not have right adapter to check compression, but I can hold my thumb over the plug hole while it is turning over easily. Pulls over extremely easy with rope.(No resistance) Has good spark. Plug is not fouled. No apparent oil leaks, but if I recall, it was blowing smoke the last time it fired up.
    6,811
    My crystal ball is telling me its time for a top end rebuild .
    3,415
    Yup, sounds like your gum ball machine is broken!!
    Unfortunately you can't get the top end off with the motor in the bike like with the 200/225 Yamaha..I always like that about them.
    Not feeling any compression with your thumb over the hole isn't a great start!!
    Out on the bench and pop it open..grab some 411 and maybe some pics
    My prediction is you'll need some parts..hopefully not your flux capacitor like 'kwheeler'..
    We'll help anyway we can..good luck.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    MN
    3,263
    Make sure its not a stuck decompression lever, right side front corner of the head, lift it up and make sure it drops when you pull the recoil, if not theres your problem. Also remove the valve adjustment caps, pull it over and see if the intake valve is moving, you said plug isn't getting wet, i have had two cases where the adjuster on the rocker came loose, the 10mm nut backed off and fell into the head by the valvespring, now the clearance starts to open up and you slowly loose operation of the valve. However this would not cause a loss of compression, but it would cause a loss of intake/fuel getting into the cylinder.
    Sounds like you might have a stuck open exhaust valve, which is why i suggested the decomp lever, so check that out first. If it was smoking a bit it might just be time to toss it on the bench, get a top end gasket kit, timing chain and guides and check the bore, maybe if your lucky a hone and new rings, otherwise consider boring it out as well. Fix it right and it will outlast the kids... LOL
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    May 2013
    saskatchewan
    10
    Thanks guys. Got motor pulled yesterday. Drained oil and chunks of metal in filter. Motor is on bench but I am stuck in appointments for next two days. Will get some pics when I crack her open.
    Jan 2013
    minnesota
    5,911
    Hello
    Spray carb cleaner in intake while it is apart and see if valve weeps, do same to exhaust. Check cam it may have gone flat which would cause steel shavings not aluminum [piston] shavings but since it smoked it does sound like it at least needs a ring job.
    Good suggestion by kb on the compression release also.
    Hopefully the following will help you some.
    OEM SERVICE MANUAL
    http://www.kb0nly.info/ATC/index.php?dir=ATC200M%2F
    OEM NOS PARTS FOR SALE OEM FICHE SHOWING OVERSIZE PISTON AND RINGS AVAILABLE ITEMS 2-4
    http://www.cmsnl.com/honda-atc200m-1...row13101958671
    WIESCO OVERPRICED FORGED PISTONS
    http://www.wiseco.com/ProductSearch.aspx
    Oct 2009
    FF, Man.
    774
    Welcome to the site!, Where in Saskatchewan are you from?
    My 3WW Feedback Thread:
    Salut Gilles
    May 2013
    saskatchewan
    10
    Well guys I finally got a chance to start on this motor.
    Camshaft is out and appears???? to be ok.
    My micrometer is to small to measure the lobes.
    Cylinder head cover is off and I haven't noticed anything unusual.
    I have never had one of these apart before, so not exactly sure what to be looking for.
    Next step is cylinder head removal I guess??
    Attached pic of camshaft.
    MN
    3,263
    That cam is certainly not the worst i have seen, looks like some wear on the journals but not horribly so.
    You mentioned chunks of metal in the oil, did you try a magnet on them to see if they were steel? If they are aluminum i would guess the timing chain is sloppy loose and wearing some metal out of the timing chain galley, i have seen them take off a couple pieces especially at the bottom just above the crank sprocket there is a bump out in the casting between the two sides of the chain, the chain gets slack and it wears against that spot and you get chunks of aluminum in the oil.
    I would keep tearing it down, pull the head, inspect the bore and piston/rings, and look for the source of the metal. Inspect the valves good!
    May 2013
    saskatchewan
    10
    Well...Got the cylinder head off. Filings are aluminum. Chunk missing on edge of piston. Can't seem to attach pics. Too big.
    MN
    3,263
    Dang, time for a new top end!
    You might have to resize the pictures. A good free image editing program i use all the time is irfanview its a freebie, has a quick resize on the menu, and best of all did i mention its free? LOL
    May 2013
    saskatchewan
    10
    Thanks man.
    Think I got them this time. Going to pull the piston next. What do you estimate the cost of this little project??
ID:	169591Click image for larger version.
    Jan 2013
    minnesota
    5,911
    Hello
    Here’s .050” OEM piston and rings in case you need this size and don’t find anything cheaper. Try partzilla.com also.
    OEM item 3 .050” piston 13103-958-670
    http://www.xtremeusa.com/pages/OemPa...VM3EE14VM3E15A
    OEM item 2 .050” rings
    http://www.cmsnl.com/honda-atc200m-1...5.html#results
    Hope this info helps
