Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 78
Thread: Field Find 86 350X
  1. #31
    May 2015
    San Diego, CA
    1,800
    This carburetor is just a gift that keeps on giving. Broken, frozen bolts...barely impacted the screw that holds the idle adjuster now a hole in bowl .
    Thanks guys for the tip on PB......I have some in a small container but it looks as if a parts carb is in order. A free or near free bike is one of the most expensive things you can buy....... that I've learned long ago.
  2. #32
    Apr 2012
    USA
    4,129
    And that is why you get two of the same machine for free, so you can make one out of the two, and sell spare parts to keep the investment low .
  3. #33
    May 2015
    San Diego, CA
    1,800
    True words.
    even knowing this I still do it. It's like I got a disease.
    ps2.....I keep looking but then I dont. Usually things just present themselves and if I can I get it. At bare minimum the tires seem to be holding air just fine. I inflated them when I brought it h pool me and they're still good. The front has a plug from a patch but still holding air. I guess I have to be grateful for what I have.
  4. #34
    Apr 2012
    USA
    4,129
    To be honest, I never gotten a free machine, but I do buy a lot of parts machines. Having enough room and time, you can almost always find a good deal on a 2nd machine, just how much time can determine how plausible it is. Same theory has a spar carb, a spare machine to rob parts from can be a life saver.
  5. #35
    Dec 2015
    Trumann AR
    23
    Put a 400EX carb on it. That's what's on mine. It has to be polar cold before even thinking about touching the choke or it'll flood but otherwise seems like a good carburetor.
    1985 ATC350X
    2002 BANSHEE
    2000 WARRIOR
  6. #36
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by BANSHEE CHAOS View Post
    That might be something I'll do.
    Someone educated me......does an 85 and 86 use the same carb? Looking at used ones on ebay.
  7. #37
    Apr 2012
    USA
    4,129
  8. #38
    May 2015
    San Diego, CA
    1,800
    85 and 86 did use the same carb, same part number.
    http://www.partzilla.com/parts/detai...0-HA5-014.html
    perfect...thank you.
  9. #39
    May 2015
    San Diego, CA
    1,800
    A lot of the rubber parts on this bike are as hard as injection molded plastic. They might need a boiling moisturizer bath.
    It has the gear driver for the speedo but no speedometer. I see a lot on ebay but I'm unsure if some are model specific. A Goki starter came up not to long ago on ebay and probably lasted a half a day. Some parts are getting harder to find and a tick costly.
  10. #40
    Apr 2002
    s.w. michigan
    6,498
    Your speedo drive gear that is already mounted is "specific" ,,,, everything else for the most part is all the same. speedo cable can use darn near any Honda older motor cycle cable so long as it is long enough but not so silly long it loops out all about.
    If you decide to eliminate the drive gear (that if has no cable in it and rode much would either need some going thru and/or be a parts part) you will need the spacer and correct bearing seal.
    If that drive gear rotates okay enough it will fetch you some surprisingly good money on ebay if you decide to go that route on that particular part (marketed correctly with pics and description)
  11. #41
    djm0242's Avatar
    djm0242 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    Rockwall TX
    297
    Oh man you could straighten that out with a hydrolic Jack and some 2x4s! I've always wanted a 350x with electric start. I just can't imagine what kicking one would be like. Nice find man.
    79 110
    83 185S
    84 250R
    3x85 Big Reds
    85 200X
    85 ATC 70
    85 Tri-Zinger
    86 200x
    86 TRX 125
    87 TRX 250
    89 TRX 300
    98 TRX 450S
    03 TRX 350
    5 Foreman 500 4x4's
    You can never have enough! ATC250ES is still the best!
  12. #42
    Apr 2012
    USA
    4,129
    Quote Originally Posted by djm0242 View Post
    The 350x's have an automatic decompression release cable, so kicking them when it is working right feels like kicking a 125cc dirt bike, really easy. However, if the cable is missing or not adjusted correctly and the engine is in good shape, it is pretty hard to kick. I have two machines and one in each setup. The hard to kick one I don't ride much since it is the nice looking machine and I ride pretty hard. I'll fix it some day . Good thing I never had it kick back, I'd think it could break my ankle.
  13. #43
    Mar 2003
    Australia
    1,919
    Want to sell the speedo drive gear? I will send you the piece that is taken out in place of the drive gear.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
  14. #44
    May 2015
    San Diego, CA
    1,800
    Thanks DJ. I was thinking it might not take much to get the bend back into a more straight position.
    it does kick over pretty darn easy with the compression release system.
  15. #45
    sandusky, Ohio
    127
    Sweet score
