Page 26 of 30 FirstFirst ... 16 24 25 26 27 28 ... LastLast
Results 376 to 390 of 440
Thread: ATCr125x
  1. #376
    Aug 2014
    South Louisiana
    1,915
    She took her first steps into the sunlight today!!!
    Ride report??? No mam!!!
    Fired her up... Bueno!!!
    Warmed her up... No problemo homie!!!
    Shift to first... Fuka nada!!!
    Currently removing the clutch cover now. Should have done it months ago.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  2. #377
    Aug 2007
    Montana
    857
    Quote Originally Posted by Jmoozy27 View Post
    Your really close !!!!Ride report soon??????
    DO the Best With What you got !
    My Feed back :cool
  3. #378
    9,018
    I hope to see a video with some 12,000rpm sound soon!
    It sucks to get old
  4. #379
    Mar 2007
    Texas
    5,045
    Hahaha! Sorry j. I know it isn't supposed to be funny but it sounds as bad as crap I always deal with. So I learned to redo the motor during the redo of the frame.
    Onformula1, I need to get ya to carve me up some bushings for the swinger. Will get you the specs.
    ________________
    https://www.mikesatvfix.com
  5. #380
    Carthage NY 250r rules
    2,355
    Looks great .What gas tank are you using.
    250r rules
  6. #381
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by atc300r View Post
    1985 cr125
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  7. #382
    2,355
    Thanks for the reply. I have the same rear tires you have. I use them for both MX and TT racing they work great for both.
    1985 cr125
    250r rules
  8. #383
    Aug 2014
    South Louisiana
    1,915
    Awesome, they looked like they would work well on the track. Did you cut them at all? They were not easy to seat the beads. One of mine leaked for over a week until I could reshape them with a heat gun. Now they are airtight.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  9. #384
    Slidell, LA
    4,738
    Eh...its probably not going into gear because the rear subframe mount wasn't sturdy enough
  10. #385
    2,355
    No, Im running them in stock form.When I mounted them the first one was no prob.Second one I have to sit it on the heat for an hour and it pumped right up.
    250r rules
  11. #386
    Oct 2013
    Wherever I May Roam
    3,757
    Or because the clutch doesn't slip enough when fully engaged
  12. #387
    Oct 2013
    Wherever I May Roam
    3,757
    Why the big gap between the seat and tank?
  13. #388
    Aug 2014
    South Louisiana
    1,915
    30 yr old seat pan with a lot of flex
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  14. #389
    Mar 2007
    Texas
    5,045
    JM, pull the clutch cover off and pull some of the clutch plates and fibers out, look at the basket ears. you have find the basket has ear groves and that will cause issues with disengagement. if you find that to be the case, pull the basket off and using a nice hand file, you can smooth the groves out and out it back together. it should work better when done. I have had to do that with several engines over the years.
    if nothing else, removing, cleaning and reassembly of the clutch can also help it start to operate smooth again.
    then again that rear sub-frame.. it could be causing you havoc!!
    ________________
  15. #390
    Aug 2014
    South Louisiana
    1,915
    Everything looked good when I pulled it out. They were probably just stuck from sitting so long. My plan is to clean and reassemble this weekend. I feel like that will solve it.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
