Everyone has their favorites for one reason or another but I hear all the time about the superiority of the modern 4stroke 450 class over the old 250 2stroke engines. I myself find this comparison completely annoying. For one thing the comparison is like pitting a weed eater against a lawn mower. The displacement is nearly double and the power output nearly equal.?. Sure it has tractability but that's not the point. The 4stroke 450's where basically one cylinder shaved off of a massively researched and engineered Formula 1 engine. With the same amount of research and development things would be different. And displacement being equal there is no contest. Why not put 450 2 stroke engines in the 450 class? Would that then flatten all the hype? I'll bet the 2 stroke is overall lighter as well as outputs more power.
The following is reference information:
Michael Harrison from the DeepScience BIGENZ team has this to say:
Most of what is written on advantages and disadvantages of 2 strokes Vs 4 strokes is not actually correct.
Take for example the lubrication issue of 2 stroke engines, sure small chainsaw engines may have the oil mixed with the fuel but this is not a direct result of the engine being a 2 stroke, this is just a result of someone designing a very simple engine. look at any large Caterpillar, or Detroit 2 stroke they have conventional oil sumps, oil pumps and full pressure fed lubrication systems and they are 2 stroke!
Also, the argument about valves of 4 strokes versus the reeds and ports of 2 strokes is also incorrect. Sure some simple 2 strokes may use very primative systems to achieve the conrol of fuel/air mixture into the engine and exhaust out of the engine but again this is not a function of them being 2 stroke! I've worked on 2 stroke engines that feature poppet valves in the head (like a standard 4 stroke) - but they are definately 2 stroke - it's just that engines like this are not so much in the public eye - next time an ocean liner (ship) pulls into port check out its 2 stroke, turbo charged, direct injected diesel engine!
Finally, the arguments of simplicity, weight, power to weight, and cost of manufacturing are not a function as such of 2 stroke versus 4 stroke engines. The mistake of most of these commentaries is that they are comparing a simple chainsaw 2 stroke engine with a complex 4 stroke engine from a automobile - not a very fair comparision.
As far as the exhaust emmisions of 2 strokes - check out the Surrich/Orbital 2 stroke design that Mercury outboards are using - this is as clean burning as any 4 stroke.
The ONLY correct comparison of 2 strokes with 4 strokes is that a 2 stroke can (in theory) produce twice the power of a 4 stroke for the same sized engine and the same revs.
