For a tri z if it makes any difference
Cheers mate. Looks similar to me. But I can't remember what the others look like
Measure the volume. Put a plug in it, top it off with water, and measure the volume. I have a Sprock head for my Z. I think he only made stock and 50/50 domes. The range is probably around 20 to 22cc.
If I'm remembering right. He made 3 different domes at the start
If its a sprock run race gas.
I have had both the BigBore and stock bore domes relieved to allow for pump gas to run. This is on the advise of my motor builder to smooth down the hit and vibration related to the flat high compression of Sprocks domes.
I run 50/50 in mine, around 100 octane.
Hi.just filled the dome with water.it measures 16ml on my syringe. I take it . It's not for pump gas.
I only filled the inner dome piece. ..should I fill it to the first edge. Inner o ring....think I've answered my own question
I should of looked more closely befor I asked the question...just found a number stamped on it..25. Cheers for all your help anyway.ian
Try Off-road Innovations for any Sprock products you’re looking for. If anyone has parts it will be them.
Do you have the stock head? Just shaving .020” or .030” of it might be your best option if you want to run pump gas.
It sucks to get old
