Nice job so far, that looks like it is very well done. I'm sure it will make a nice ride, or atleast something to talk about in the corner of the garage, TC...
84 hubs on what looks to be an extended 86 axle. JP or Finishline made axles for the 86 T3 that used the 84/85 splines so the smaller bolt pattern could be used, all to allow 8 inch rims.
Hmmm Interesting, it may be an '86 axle! I know its a lot wider than a stock '84. I'll measure tomarrow. Thanks!!
heres a pic of my nos plastic......10 years in the making!! LOL
i actually have a 85 250r frame that was modified to fit a kx500 and a custom hand coned pipe made for the 250r frame/ kx500 engine. maybe one day i will build it or sell it.
looks like you have got it all figured out. nice project.
It very well could be someone put an 84 axle and carrier on the 86. It would bolt right up.
The oem stickers on that new plastic make it that much more rare/valuable. Is this going to be a show bike? If not I would sell the plastic on ebay and get some maier skins. That NOS plastic set would command a high price.
4 Strokes are NOT the wave of the future!
Hey all, here's a quick update. So the 250R subframe wasn't cooperating with the tecate plastic, so on to plan B. I cut the honda subframe off, and used the top part of the original tecate subframe, the 250R support braces......
Here are some pics with the subframe supports, and gussets in place.
Here the plastic is mounted, does it look like the rear end stink bugs? It looks a little high to me, I may just be over sensative. I have looked at tons of pics, and can't decide, Tecate boys?.........
Next steps.....
1. Make front and top engine mounts out of 1/4 inch strip aluminum stock
2. Have custom exhaust made
3. figure out a chain slider to use
4. Have cylinder ported, and plated by MaxPower/RPM's
5. Start it up
6. ride it, if I like it on to step 7
7. Dissassemble and powder coat frame and what not. make frankenbike pretty!
I'm trying to decide what color the frame, swingarm, and engine should be, and I was hoping on you all giving my some input.
I dont know who's T3 this is but it has been my inspiration.
