on my restored 200e the rear tires will only hold air for about 10 to 15 hours the tires are new so it must be slowly leaking around the bead. Should I try some tire slime or just tube them. I dont want to wreck the tire or rim, how messy is the slime when it comes time to change the tires. Ive never used slime before. also can you install the tube just breaking the bead on one side?
MY FEEDBACK THREAD-
to get a rebuild has too much crankcase pressure and wont shift need piston, rings
