Does anyone have any experience with this guy, how are the quality of his bolts? How do they look? Are they complete?
Thanks Denn
Thanks Denn
I bought a kit from this guy, and it is worth every penny. I bought it for my Tri-Z and all the stuff is there in the correct length, Im sure the a lot stronger than the 20+ year old stuff you got on it right now, I forgot the grade of the fasteners so Ill get that back to you in a little bit. They look decent, stainless steel, and the will keep lookin decent because they are stainless. He also ships in a timely matter.
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
Yes i also bought a kit for my Z and it is worth every penny, Top notch lookin stuff, the only complaint i have is its all flat washers...no lock washers,,,and i like lock washers on certin bolts...lol
1985 Tri-Z-
Originally Posted by mywifeknowseverything
I also bought a set for my 350x. I purchased them mostly for the engine bolts. As far as the rest of the bolts its "hit or miss". If your going bone stock no problems, aftermarket items can be a little more difficult with the correct bolt length. Overall you still can't beat his price considering its stainless. Overall I like his fastners.
Current Rides:
All Red's!
I've bought a few kits from him, only kit I had any problem with was the 85-86R kit. a few bolts were a couple mm short and wounld'nt go through the nyloK.
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
If this guy is selling the stainless steel kit beware that stainless is not noted for its strength. Its heavy and it breaks easily. I have looked into this. I have also contacted a metalurgist about this. If you want that shiny look then go for it. thats all its good for, but i wouldn't trust it on the track or trail. I'll bet money this guy doesn't tell you what type or grade of stainless bolts he selling in the add!! I'll bet he won't tell you what the maanufactures name is. Also I'll even bet more money this stuff comes from RED CHINA. Good luck
I picked up a kit for the 85 Tecate. The rear linkage bolts and shock mount bolts were sloppy, not the correct diameter but everything else was good.
Ok guys thanks for the info, who has a good stainless steel kit that they sell. I really don't care what it costs as long as it is a complete kit. I am building an 86 250r and an 86 tecate from scratch and I need some bolts. I figure I could get a complete stainless steel kit. It would be a hell of a lot less than buying new bolts from honda. Any suggestions.
thanks Denn
Yeah, stainless definetly looks cool but I wouldn't put it in any mission critical places unless you KNOW its areally good high grade. I've broke a few stainless motor mount bolts. I wouldn't want any in the suspension parts.
I have his R kit. It's nice but I only bought it for non-load bearing parts. They do dress it up nice though if you use the small ones.
So I take it stainless is brittle metal. Glad I kept on reading this thread.
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
It's fine for low torque stuff like case bolts and what not. The only things I wouldn't use it on is motor mounts, suspension parts, footpegs and handlebars. Any of those coming loose could really ruin your day.
ThanksOriginally Posted by Dammit!
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
are they safe to use on cylinder head nuts, ya think?
I would think the nuts are safe but they're not the same style as OEM. I don't like the way they look.
