hey guys, i just got a mikuni carburetor for my 84' ytm 200e shaft drive and it ended up 42.50 on ebay. i got it but cant figure out how the valve goes in. when i screw in the carb cap the valve wont go all the way down where it should be.
Turn the slide 180
1983 KLT 200 C
1978? YZ 125
1978 Panther 5000
1939 Farmall A, 51st farmall A ever produced.
1946 International A Industrial
1973 Ford F100
while its as far as it will go?
The slot in the slide must be on the same side as the pin in the bore.
Pages 161-162.
http://72.52.143.80/~trikes/ytm200&2...mer_manual.pdf
When it stops. Im assuming its within a couple of mm of the top. Just pull it up out and spin it 180 and spin it back and fourth while your putting it in and it will find the right slots on the slide and it will go down. just takes maybe a minute.
1983 KLT 200 C
1978? YZ 125
1978 Panther 5000
1973 Ford F100
thanks guys i got it. any1 know where i can get partys like idle mixture screw and starter valve assembly for cheaper than the stealership.
