Results 1 to 3 of 3
Thread: Yamaha serial/VIN numbers
    Monroe MI
    5,787
    This is to help figure out the year/model for Yamaha's only.
    1980 - 1984 have a 9 digit serial number for the engine/frame. They will match, unless someone has changed the engine. VIN decoders will not work.
    1985~ - 9 digit on engine, 15 digit on frame. You can use a VIN decoder to figure out the year.
    I included the 1985~ numbers, in case you want to check and see if you have the correct year engine, in your machine (works on most models).
    1EV-000101-on______1985 YTM225DRN__(15 digit on frame)
    1NV-000101-on______1986 YTM225DRS__(15 digit on frame)
    1RX-??????__________1986 YTZ250S____(15 digit on frame)
    20E-??????__________1983 YT175K
    21V-000101-100100__1983 YTM200K
    21V-100101-160100__1984 YTM200L
    21V-160101-on______1985 YTM200N____(15 digit on frame)
    21Y-00????__________1983 YT125K
    21Y-??????__________1984 YT125L
    21Y-??????__________1985 YT125N_____(15 digit on frame)
    24W-000101-100100__1983 YTM200EK
    24W-100101-on______1984 YTM200EL
    29U-000101-060100__1983 YTM225DXK
    29U-060101-on______1984 YTM225DXL
    29U-100101-on______1985 YTM225DXN__(15 digit on frame)
    2FW-??????_________1987 YTM225DRT__(15 digit on frame)
    36R-??????__________1984 YT60L
    36R-??????__________1985 YT60N______(15 digit on frame)
    38W-??????_________1985 YTZ250N____(15 digit on frame)
    3X3-??????__________1980 YT125G
    4U3-??????__________1981 YT125H
    52G-000101-on______1985 YTM200ERN__(15 digit on frame)
    5V6-??????__________1982 YT125J
    5V7-??????__________1982 YT175J
    Any errors...Let me know.
    Aug 2020
    Southern Ontario
    18
    Worked for me! today I am the proud owner of a 1986 YTM 225 DRS needs a lot of work but the engine and frame match! thanks for posting this.
    Aug 2021
    Oklahoma
    Yes my vin is 29u-078948
    Quote Originally Posted by MonroeMike View Post
    Yes my vin is 29u-078948 and someone cut my wiring harness in like 5 places on each one I can't figure it out can you help me out with knowing the basic wires it has to just run please
