Results 16 to 30 of 65
Thread: my 200x Lifted MONSTER in the works
    House Springs MO
    5,494
    Have you taken into account the drive chain angle?
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    I thought about that being a problem and may need additional chain guides to keep it from rubber the frame/swing arm. Im going to put the motor in soon and check everything out and drive it around a little before sending it to be powdercoated. I saw a pic of the guy building a custom full suspension 185s and he had some good pics of his custom chain roller guides.
    Well its a +5.5 swingarm and angled down twice as much as stock (rough guess) so a little trig and its about 4" longer?? I dont really know without getting some measurements.
    nicker71's Avatar
    Jun 2003
    385
    Ive made some progress since my last post. I got the fork extensions made by dirtworks, and I made a chain guide and a few other things. Right now Ive got 17 inches of travel from under the frame to the ground and plan on making a tri z front wheel fit the front so I can run a taller tire. If I can get it to work then its a 30inch up front and a set of 28s in the rear with a nice set of wheels. I'd like to put the 200x topend on the 185s auto bottom end and powder coat everything and new plastic.
    nicker71's Avatar
    Jun 2003
    385
    nicker71's Avatar
    Jun 2003
    385
    chuckiedog04's Avatar
    chuckiedog04 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    minnesota
    369
    i like it. i don't know how it would handle but it sure has a "wow" factor
    nicker71's Avatar
    Jun 2003
    385
    Thanks, Its not good for much other than the wow factor. I just like looking at it and knowing they'res not any thing like it.
    partsmaster's Avatar
    partsmaster is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oklahoma
    153
    I like the wow factor as well. Them 25s look like 20s on that hawg
    85 ATC250ES
    85 ATC350X
    85 ATC250R
    82 ATC70
    84 ATC200X
    79 ATC110
    ATC500
    81 ATC250R
    87 TRX250
    08 TRX700XX
    96 TRX400FW
    00 Rancher FM
    05 TRX400EX
    87 TRX330R
    TRX600
    01 Rubicon
    00 TRX450S
    88 Foreman
    87 TRX350D
    98 TRX300tw
    05 TRX450R
    Tucson
    1,652
    Let's see some pics of how your chain rollers are coming along?
    Holy goofball trikes Batman.
    I would imagine a mullet is mandatory when operating this contraption, no?
    nicker71's Avatar
    Jun 2003
    385
    LOL, yeah and I was thinking of adding the ball sack thing that some of the red necks have one their trucks receiver hitch to set it off.
    Sarnia, Ontario, Canada
    3,415
    It looks...UMMM, ERRR unique, interesting.
    I think the metal testicles are understood..you can forget those!!!
    Hate to say it but with this design, I kinda see a short trip over the handle bars in your future, but the judges will hold their numbers until the video shows how it runs out and handles. You are posting a video right??
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    nicker71's Avatar
    Jun 2003
    385
    I don't ever see myself going over 25 mph with this thing, thats for sure. It rides smooth, the back shock will bottom out easly though. I need to widen the rear end a bit to help make it more stabile.
    3,415
    Quote Originally Posted by nicker71 View Post
    The leverage on that rear shock has been greatly extended of course. It probable squats 5-6 inches just sitting on it..am I right?
    She sure would be a comfy ride!!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
  15. #30
    nicker71's Avatar
    Jun 2003
    385
    Quote Originally Posted by dougspcs View Post
    Yes you are correct, the extra 6 inches of length to swingarm puts much more leverage to the rear shock. I have a shortened 350x shock on the rear to raise the height. The problem with the 350x shock is that the spring has a lower rate than a 200x spring, but its longer. Dirtworks couldnt find an aftermarket atv spring anywhere close to what comes stock on this. He did say they could probably find a spring from an anothe type of applications such as midget cars or something. But this seems to work ok the way it is as long as Im not doing any aggressive ridding, which I wont be. The 350x shock has been shorten quite a bit and only allows 7" of rear suspension travel with the long swing arm. I have the preload 3/4 of the way tightened down (but remember its a shortened shock, so it puts much more sag into the spring than a stock length 350x shock) it only sags about 3inches with me sitting on it and Im around 190lbs. So I guess I might risk breaking the spring if I bottom it out.
