Results 1 to 15 of 16
Thread: snapped my shifter off my 1985 klt 110
    Jul 2011
    Killington/Rutland Vermont
    17
    i was riding my new 3 wheeler for the first time yesterday I made it about 2 miles up the trail shifting through all the gears and as I was going up a hill and downshifting it all of the sudden got stuck inbetween gears and started to roll back down the hill.. I look down and the shifter just falls off... it looks like it snapped right off in the inside of it but there is still some of the (rod) not sure of the proper name of the part sticking out past the clutch cover where the lever is mounted to.... but that bad new is it looks like the teeth or grooves? are stripped... What is that part called and how can I fix this problem? Do I need a new shifter and rod that it slides onto to get back on the trail? and where can I buy the part?
    Jul 2011
    17
    now it is stuck in 3rd gear and I cant do anything about it with the shifter off... I tried vice grips to move the rod back to neurtal but it would not budge. Thoughts?
    jordan_muirhead's Avatar
    jordan_muirhead is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2011
    Monticello, Arkansas
    316
    I beleive the (rod) you are referring to is the shifter shaft....i have the same problem on my 185s, I need ths shaft and shifter, if its stripped you might too.....not sure about what to do if its stuck in gear
    Nubbinz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Winchester, VA
    171
    have you tried rocking it while shifting ? old trans sometimes need to be moving slightly to shift you can try bolting the shift lever on as hard as it will go, and maybe put some jb weld on the teeth on the shaft, before you bolt it down, if its not totally stripped that might work otherwise u need a new shifter shaft and shift lever... just be sure to torque your new one real good so it dosnt strip out your new shaft... kawi parts are hard to get, good luck finding a new shaft if you take that road... any old shifter should clamp onto the shaft tho, just buy one off a parted out honda 110 for like 5 bucks on ebay
    pa
    127
    thats a very common problem with the klt 110 i have one sitting in my garage that needs the shifter shaft too. its broken off the same way you mention.
    Baltimore, MD
    6,088
    I keep trying to tell everyone that the weak shifter shafts are the main problem on the klt110s. Does anybody listen? Buy ever shifter shaft you can get at the dealer.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Jul 2011
    17
    i found a klt 200 shifter shaft on ebay will that work for my smaller 110? it looks the same?? i also looked on bikebandit.com they sell them but cost an arm and a leg... yeah my shifter shaft broke on the inner knob and previous owner took a self tapping screw to it to make it look better when I bought it... it shifted fine for the first ten minutes of riding and then it just snapped under the pressure.... I was able to get the self tapping screw out and dug out the end of the shifter shaft from the lever with some needle nose pliers. both the lever and whats left of the shifter shaft appear stripped I tried mounting it but its a no go.... I need both the lever and the shaft unless I weld... which I dont want too....
    Jun 2011
    Conroe
    83
    O wow i have herd a lot of good thinks about the klt 110s but the shifter shafts allways seem to be the problem how hard is it to do this maybe you could post pics of each step you have you take to do it i also have one and mine looks like its welded on it seems to shift fine but i dont want to be stuck with out a trike if it does
    Jan 2011
    316
    check the classifieds section, and evilbay if you dont find anything there
    Nov 2006
    Huffman TX
    891
    like stated the "rod" is the shift shaft. I feel ya pain, im currently replacing the "shift shaft" on my bayou 220 right now and had to replace it on my 87 200x. Its prety simple really just remember what goes where. Good luck to ya man
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    Jul 2011
    17
    come friday I am buying both a new shifter shaft and a shifter from bike bandit. no luck on ebay and the classified section on here says "private"
    Jan 2011
    316
    good luck to ya, after i get some things sorted out ill do the same
    "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools"
    "Trikes Owned-1983 Honda 185S- eBay 200x carb, and uni filter-Sold"
    1986 Honda Big Red 250ES
    I bleed Honda Red You Should Too
    Three Wheels Are Better Than Four
    R.I.P ROOSTER-Dustin Ray Ferguson(9-20-89)-(9-22-08)
    R.I.P Jesse Ray Cash(6-17-93)-(12-14-09)
    pa
    127
    how much are they on bike bandit, and did they have them in stock?
    Jul 2011
    17
    yeah they have them and they are just about 45.00 for each the lever and shift shaft
    Monroe MI
    5,787
