Hi, I recently purchased a 80's trx125 in need of work.Has been sitting outside for couple years.
Did get the engine to start using starting fluid.
Brakes need work, drive chain, frozen cables, rusted out gas tank, ripped seat and loose front end parts, water in pull start.
I tore the carb apart and lots of corrosion and rust, got it cleaned as good as possible. Ripped a couple orings and float bowl gasket, still pitted from the corrosion. Would it be better to buy a rebuild kit or a new carb off ebay?
thanks
