Results 16 to 30 of 34
Thread: three wheeler conversion...
    NC
    907
    Quote Originally Posted by Dirtcloud View Post
    What do you mean it doesn't fit, I know it fits I have done it.
    Do you have pics of this or a build thread somewhere? How about details? Modify the mount how?
    Quote Originally Posted by 200x350xtriz250 View Post
    Thats the thing. In 15 years I haven't heard of one be put in an ATC with "just a mount cut".
    Please educate us on the exact process........
    Dec 2009
    BFE
    1,202
    The 200sx quad engine does look very similiar to the 86-87 200x. If any engine was to just bolt into place on a 86-87 frame that engine is prolly going to be the closest. As for it just bolting in I have heard it but never seen it done. I even started a thread asking if anyone has done the swap but nobody had any pics http://www.3wheelerworld.com/showthr...ght=200sx+swap
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Northern, California US
    105
ID:	139882Click image for larger version.
ID:	139883Click image for larger version.
ID:	139884Click image for larger version.
    The rear mount in the pictures that is a little off color is the one that needs to be modified. This is done by first cutting it off second adding some length to it finally welding it back on the frame. This makes the rear mounting wider which is what is needed to mount the engine. After that the engine will bolt right using the stock 200x mounts and bolts with the exception of the one that has been modified. A battery box will also have to fabbed up and mounted to the frame, but I never got that far.
    Also apologies to 200x_rider for kinda highjacking his thread.
    What about a pipe, carb, airbox, top engine mount and sprocket alignment??
    Got a pic of it as a runner? Sounds like you just got it in there and never finished.....
    Which would still not prove it as an easy swap; Just trying to get honest info about all this.
    105
    Yes your right it is not finished that is how it sits right now. I am not saying it is a easy swap but I am saying it can be done without a lot of hassle. The cylinder head on the trx engine is the same as the atc engine, therefore exhaust, carb, and top mount are all bolt on. Sprocket alignment is also right on the money. Some day I will finish the bike and then I'll know if this swap is really worth it.
    Husky250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    NE Ohio
    264
    [QUOTE=200x350xtriz250;1092228] Putting a 300ex swingarm on is also a very involved process.
    Involved yes, but not impossible. The finished project is in my garage; cut chop, weld. A little milling to get the bearings in is also required but not terribly difficult.
    Nov 2006
    Huffman TX
    891
    dirtcrasher the topends are exactly the same... so just put the 200x pipe/airbox/airfilter...
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    Huffman tx.
    37
    wow guys all i was saying is i heard it could be done.. me only owning one three wheeler in my life and having only a couple of friends that still ride atc's i have no idea about anything thats why i was asking so you dont have to be a dick about it and say im messed up for asking if there was a way i could do it instead of spending money and end up in failure just to spend more money when people on here can just tell me if it would work... obviously the 200sx motor fits with one modified bolt in it onto a 86-87 frame.. the 300ex swingarm will fit onto the 200x frame (so i heard idk if thats true or not) and the 350x shocks i believe fit too.. this would be a multible year build as i am not made of money i would just like to make something no one person has alike and i need a project to keep me off the video games. thanks for your help dirtcloud and i will post pictures throughout the process.
    ~~~~My rides~~~~
    02 TRX400EX
    85 YTM200ER
    86 TRX200SX
    88 LT250R
    All they're really trying to say is it's not nearly as easy to accomplish as you think, nor is it worthwhile. I tend to agree. Sell the square and buy a trike. Problem solved.
    Huffman tx.
    37
    i wish three wheelers were common down here lol anyone that pops on craigslist someone thinks they have a mint condition anitque and try to sell it for around $2000.... even when its broken down and what not.. when i find one cheap enough for the looks its in then ill buy a tricycle lol
    ~~~~My rides~~~~
    02 TRX400EX
    85 YTM200ER
    86 TRX200SX
    88 LT250R
    Quote Originally Posted by three_wheelin45 View Post
    I know that and I said that..... But that doesn't mean that the way the bottom end mounts up aligns everything in the ATC frame correctly.
    Quote Originally Posted by 200x_rider View Post
    Were trying to help you....Not hear to be negative, rather here to save you the effort. Dirtcloud has a motor in a frame, not a running 200SX motor in a 200X frame completed. I can stuff a Kawasaki motor in a 200X frame tomorrow and tell you it fits too if you'd like. Or would you rather hear the truth that many of us have tried and realized the repercussions of such swaps??
    The 300EX swingarm does not fit, it is much wider.
    The 350X shock does not fit either.
    A 350X steering stem is larger than a 250R stem (the fork tubes are 2mm's larger), so I doubt that fits either or the steering stops match up.
    Anything can be done, but you better have some good equipment and skills or listen to what people say and make a better choice to save yourself time and money...........
    May 2011
    eden,ny
    3,481
    funny this comes up right now. over on .org right now it's the same engine but with a recoil,electric start and an auto clutch. hmm, reverse was never mentioned.
  15. #30
    ^ Got a link Ben??
