When I joined the site, I wrote that since I have read the Bigbore thread about the 480R conversion, I have been dreaming about a 2nd gen 480 conversion.
Everything has started with these:
http://www.3wheelerworld.com/showthr...highlight=480R
The ‘82 finished is here: http://s.com/?p=926
But I immediately preferred make the build with a 2nd gen because I believe the chassis/suspension is better.
After several hours of search here, on 3WO and AF.com, I have only seen these about 2nd gen 480R:
http://www.3wheeler.org/vb/showthrea...highlight=480R
http://www.3wheelerworld.com/showthr...?highlight=480
But unfortunately the rare pics on these threads are too small to see details on biggest issues of the build:
• Engine mounts: specific mounts to make the 480 engine fit the 250R frame,
• Kick starter: modifications to make the kick starter clear the R frame,
• Exhaust pipe: modifications of the CR 480 pipe to fit the R frame,
• Gear shifter lever: modifications to make the shifter lever clear the R frame.
So any help, info and above all pics would be very much appreciate! Please don’t hesitate to post here if you have any.
After several months/years of search, I found a ’83 480 CR engine (with 5 speed gear box, the ’82 have only 4) in 2010 spring, and in the last couple of month a cheap complete ’84 250R.
So now I can start the build. I’m afraid it will be a long build because I will not really have much time for him.
My objective is to not make any modification on the frame: no drilling nor cutting, nor welding, nor grinding. Only bolt-on mounts.
I would want at the end of the build that the frame could receive interchangeably the 480 or original 250 engines.
I started by taking measurements of the 250R front sprocket position.
After that, I put the 250R engine out of the frame and put the 480R engine with its rear mount on the frame.
The lower motor mount and the rear 480 CR mount lined up perfectly and the swingarm bolt went through without a problem.
With these 2 mounts bolted the sprockets lined up perfectly, in the same position than the 250R engine. The engine just has to be stalled laterally!
The rear mount will be a mix between 250R and 480 CR mounts.
I am at this stage: take measurements and design the rear mount.
Okay, enough blabla, now pics!
The ’84 250R when I bought it:
These 2 engines have to be able to be bolted on the 250R frame…
480 engine put on the 250R frame:
The 480 just fits in the 250R frame!
Rear mount side view:
s.com/?p=926
