And while Im asking questions, How do I adjust idle speed... This carb is alien to me,,,
1986 tr200 Fatcat
1985 ATC250es, all original but tires, need a right side cover
1983 ATC200e All original but tires and wheels
DG pipe, uni filter, jetted
1983 KLY250C Prairie (for sale as parts)
1982 ATC70 (x3)
 At The Back Of The Pack
						Arm chair racerAt the back of the pack
						The banshee axle ipad the same except the threaded part has more threads to accept two nuts instead of two km nuts like the tri-z has.
85 tri-z (in pieces)
421 cub banshee
						Arm chair racerFirst time rider
						 New to the board
						Arm chair racerNew to the board
						New to the board
						anyone know of another source coil that will work? aftermarket ones are junk, gone through 3 of them now. Im talking about the coil on the stator. Thanks
 New to the board
						New to the board
						got someone to wind me a new one with good high temp wire for $75 bucks. cant really beat that
 New to the board
						New to the board
						what about the rear brake rotor and axle hub? mine would probably be fine but if I could get a new one for another model that would be nice.
You can go with the banshee axle hub but you will need to switch to a banshee carrier to bolt the calipers up. Otherwise I ve seen an awesome thread on here of a Tri Z build and the guy ran 04 YFZ450 wave rotors front and back. Silght mnod on the mounting holes and some sapcers at rear to align with caliper but said no big deal. I am in the same boat my rotor is useable but not pretty. Think I am going to try YFZ rotor route and I will post back when I get it done to let all know if it worked out. Here is the link to the thread,3wheelerworld.com/showthread.php/71073-Top-Tier-Tri-z-REINCARNATED/page15?highlight=skid+plate"] sweet Z for sure!!
Currently Owned
1986 Yamaha Tri-Z 350???
1985 Honda ATC 70
1985 Honda ATC 250R
2006 Suzuki LTR450
2005 Suzuki LTZ400
2005 Polaris Predator 50
2004 Polaris Predator 90
2-Honda Trail 90's (need to be brought back)
Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
						 I'm the one with all the 2 stroke around here!
						The day begins with 3WW
						It is the 04-05 YFZ quad rear rotor you need. It fits the Z hubs fine front and back if you shave the holes a few thousandths. You will have to space the rear caliper over about 1/4-3/8ths of an inch. I found and used this set-up on both My 310 Drag Z and The raffle Bud light Z and it worked great.
Banshee carrier does NOT fit..
 New to the board
						New to the board
						most honda kickers that kick forward will work.
						It's been asked before on here a few times but never answered.
What are the clutch basket options?
Is the Sprock billet outer basket the only option?
What about inner basket?
There's plenty of both on ebay but mostly look like junk.
Need to get something sorted but not too keen on spending good money on shite
I believe 83-88 yz250 is the same. Definitely 85 is the same I'm running one currently.
85 Tri-z Basket Case
The 86-87 200x footpeg is a mod mentioned in another thread? One side was a supposed bolt on has this been confirmed?
						Was anything found out on other calipers that will work?
200x - I think I have 7 of em?
10 70's
3 350x's
Tri Z
225
kxt
and the 90 110 125m that I need to get rid of.
YT175 with rear suspension sold
200es- SOLD !!!!!!
