Results 1 to 15 of 24
Thread: Bent ATC250R Frame
    Nov 2013
    Chula Vista ca usa
    29
    Bent ATC250R Frame
    My cousin wadded my trike last season and bent the frame a little anyone have any ideas on how to straighten it?
    House Springs MO
    5,496
    Frames are cheap. Buy another and save yourself the headaches.
    May 2013
    Henderson, Tx.
    977
    Have you tried crashing it the opposite direction?
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by 6speedthumper View Post
    have you tried crashing it the opposite direction?
    lol.........
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Jan 2014
    La
    1,062
    New frame definitaly.
    Hampton, Virginia, C.S.A.
    2,664
    haha i fixed a set of 350x forks that way one time
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Apr 2006
    SE CA Dez in the sandbox
    900
    Got an '85 frame already for you and in El Centro
    So it's right (lol) and bent. If you were a stubborn SOB, it could be chained down and a cum-a-long could be use to tweak it back.
    Yes bending metal makes it weaker but anyone can choose to do so.
    However, 100$ frames are found all day long.
    Pay yourself 25$ an hour to fix it and is it worth possibly having a weak frame and a few things still outta whack?? after hour and hours and it could get ya killed.
    EDIT - With a look at that foot peg, please burn your cousin or beat him badly unless he offers to pay and PLEASE throw this frame away.
    devore,ca
    1,052
    I tried to straiten my 350x frame with a little success. Hydraulic press, some chains and a tractor were involved. Do yourself a favor and just get another frame. You will never get the bent one right.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jackson MI
    1,688
    Looks like a minor subframe tweek... Chain that baby down and pull it back straight..
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    ^ Finally, a good use for a cement truck!!
    Oct 2013
    Wherever I May Roam
    3,757
    Nice work Jason.
    As DC mentioned, in my opinion as well, the footpeg mount is the deal breaker. See how the boss points downward too? The twisting that occurred at that point is severe, and won't be an easy or quick repair, if done correctly and with safety in mind.
    Jackson MI
    1,688
    Yes, mine was just the subframe and forks. I didn't notice the peg was bent on yours.
    DC, your right, concrete trucks are good for,,,, sinking to the axle housings in your yard, and straightening 3 wheelers, and that is ALL!!!
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Quote Originally Posted by Jason Hall View Post
    Thats why I said it, every damn one I order has some sort of issue and if you bury one to the axle and look at my backhoe, it will growl.....
    East Central Illinois
    677
    If you scrap that frame, I would buy the upper chain slider mounting piece, between the two downtubes on the right side.
    nstyle73
    "When in doubt, wind it out"
    Feedback: http://www.3wheelerworld.com/showthr...k-for-nstyle73
