Yamaha 225DX delivered to me for $200, not running. O.P. said "I cleaned the carb, now it won't start". The carb was not in good shape.
Nothing special on the revival just doing what needs done. Avoiding any restoration type work as much as possible. I did have to blast and paint the head pipe but otherwise just maintenance ans service. I had a lot of leftover
parts from my other DX build that I was able to use on this one.
The bad:
Bent bars
Bent forks
Car tires, bald
Empty muffler, no clamp or gasket.
Dirtiest carb ever
Seized choke plunger
One bowl screw
Stuck float
Destroyed and buried mix screw
Shot rear axle bearings
Caked on oil on everything
Torn boots
Bald front tire
No axle nut on the front
Front axle destroyed by hammmer
Improperly installed front brake hub
Tight valves
Blown rear shock
No airbox cage, element, lid
No battery
Oxidation and broken plastic
Missing upper engine mount bolts
Ruined rear hubs
Heavy rust on head pipe
Etc etc etc.
The good: Its a three wheeler!
