Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 76
Thread: MPDano New Project: 1985 ATC 250SX **DONE**
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    She's pretty thrashed but 90% there. Just verified starter spins great with good compression. Didn't hook up my compression gauge as the exhaust header is missing and not sure if that would affect the reading. I removed the carb and took it apart and put in my Berrymans Can. Ordered a carb kit, fuel petcock and starter solenoid.
    Here is what I know I will need: (prices shown are already bought)
    ATC cost: $80
    Carb Kit: $16
    Starter Solenoid: $7.50
    Fuel Petcock: $6.50
    All Plastics: $287 (gonna go all white)
    Decal set: $41
    Front brake lever/perch: $23.50
    Front Brake cable: $14
    Front brake lever cover: $20
    Front Brake Cable Stay: $17.50
    Front brake cable holders (top & bottom): $10
    Front brake adjuster parts: $23
    Red Kote fuel tank liner: $25
    Steering Stem nut/washer: $15
    Two rear tires - 22x11-8: $110
    Metal air stems: $6
    Header Pipe: $33
    Flex Pipe/Hanger: $15
    MRP Muffler: $0
    Header Gasket: $7
    Headlight Assembly: $32
    Headlight/bulb: $70
    New Grips: $10
    Handlebars: (I have some Renthal bars lying around) $0
    Seat Cover: $26
    Shock Boots: $16
    Reverse Cable: $14
    Rear Brake Lever Cable: $11
    Choke Cable: $12
    Instrument bulbs: $8.50
    Oil Filter: $5
    Spray Paint: $20
    36 ball bearings for steering: $8
    Ignition Switch: $11
    Starter Switch: $28
    Rear brake adjuster: $19
    Fuel cap gasket: $9
    Fuel Tank Dampers: $11
    Fuel tank L rubber: $12
    Instrument Panel: $25
    Fender holder rubber cushions: $20
    Air Filter: $24.50
    Rear Tail Light: $18.50
    Tail light mounts (rubber,pins and collars): $25.50
    Front and Rear Mud Flaps: $85
    Battery Liner and battery holder: $40
    I'm gonna keep a tally on this post if I am allowed to edit it as I go.
    Total in parts as of 1/8/2017: $1235.00 plus $80 for the ATC
    In disassembling the carb, I broke the pilot jet off, do you have a way to remove the broken piece?
ID:	235813Click image for larger version.
ID:	235828Click image for larger version.
ID:	235829Click image for larger version.
ID:	235830Click image for larger version.
ID:	235831Click image for larger version.
ID:	235832Click image for larger version.
ID:	235833Click image for larger version.
ID:	235834Click image for larger version.
ID:	235835Click image for larger version.
ID:	235836Click image for larger version.
ID:	235837Click image for larger version.
ID:	235838Click image for larger version.
ID:	235839Click image for larger version.
ID:	235840Click image for larger version.
ID:	235827Click image for larger version.
ID:	235826Click image for larger version.
ID:	235825Click image for larger version.
ID:	235814Click image for larger version.
ID:	235811Click image for larger version.
ID:	235812Click image for larger version.
ID:	235815Click image for larger version.
ID:	235816Click image for larger version.
ID:	235817Click image for larger version.
ID:	235818Click image for larger version.
ID:	235819Click image for larger version.
ID:	235820Click image for larger version.
ID:	235821Click image for larger version.
ID:	235822Click image for larger version.
ID:	235823Click image for larger version.
ID:	235824Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Cleaned out the rusty tank with muratic acid today. Got the idea off a youtube video. I should have taken a before pic but it was covered in rust bumps all over the inside of the tank. Rinsed it out with some water then some pre-mix so it's has a bit of oil in it to keep it from rusting up again. Next is to get some of the Kreem tank liner and be done. I've used Por15 in the past but it was expensive. Also, removed all the paint off the tank exterior to get painted after the tank lining.
    Also, banged up my battery holder so it actually can hold a battery. Also straightened up both foot pegs as they were bent to hell.
ID:	235842Click image for larger version.
ID:	235843Click image for larger version.
ID:	235844Click image for larger version.
ID:	235845Click image for larger version.
ID:	235846Click image for larger version.
ID:	235847Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Got the carb kit and starter solenoid. Had to jump the ignition switch as well as the rectifier power. Most likely the igntion switch is faulty, gonna get a new one anyways. Shes running, so it's time for the dismantle and repaint that frame.
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Good work getting it running. Did you find that trike at the bottom of a river?
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by 82 250r View Post
    No doubt. The Craigslist River.
    MPDano's Avatar
    Sep 2014
    Removed the engine, pressure washed the frame, engine, skid plates and lower triple clamp. Then painted the engine low gloss black, the rest in semi gloss black. I hit the rusty areas with rust restorer first, it makes a great primer.
ID:	236349Click image for larger version.
ID:	236350Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Put the motor back in. Hooked back up the harness. Put new steering bearings, got 36 from the local bike shop. Love the simplicity of these old Honda ATC's.
ID:	236420Click image for larger version.
ID:	236431Click image for larger version.
ID:	236432Click image for larger version.
ID:	236433Click image for larger version.
ID:	236434Click image for larger version.
ID:	236435Click image for larger version.
ID:	236436Click image for larger version.
ID:	236437Click image for larger version.
ID:	236438Click image for larger version.
ID:	236430Click image for larger version.
ID:	236429Click image for larger version.
ID:	236421Click image for larger version.
ID:	236422Click image for larger version.
ID:	236423Click image for larger version.
ID:	236424Click image for larger version.
ID:	236425Click image for larger version.
ID:	236426Click image for larger version.
ID:	236427Click image for larger version.
ID:	236428Click image for larger version.
    Dec 2012
    812
    Nice to see you decided to give her a restore, rather than part it out. It's coming along real nice. Did you have any problems removing the front axle? My new 250SX's front wheel bearings are shot, and I've heard the front axle can be a real bugger to remove. I also notice pic #12 the drive shaft boot has an impression the same as mine did when I bought it, however I was able to shape it back to it's original 'ripple', and it seems to be holding. After seeing yours I'm thinking now that maybe it's common for them to develop a divet like that.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by Big G View Post
    Thanks, yes I hate parting out stuff. I always see value in getting a thrashed atv and bringing her back to life. This is a keeper. My front axle came out easily, surprisingly. I had a 250R that gave me issues with the axle.
    I was going to add some heat and get that ripple out of the boot, but it will most likely come back after time. The boot is the original and I decided not to replace it as there no cracks and it was still supple. I like to spray all rubber parts with silicone.
    The plastics will be the last things to replace as they are costly, almost $300 for the set. I'll do more to it this weekend as I bought more bits off ebay.
    May 2016
    OH Canada
    1,102
    It is coming along nice. It was in rough shape.
    Engine looks great. I like the way you removed the paint on the side. Little things like that make a big difference in looks.
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by Rob Canadian View Post
    Yes, used my orbital sander, which already had a very fine disk on it. I saw a real nice restored one (250SX) with that paint removed and said, why not. If I only had deep pockets, this project would be done already. We are heading on the first Desert Trip of the season the weekend before Thanksgiving and I'm bummed I wont be able to take it. Will have to make do with my other toys.
    MPDano's Avatar
    Sep 2014
    Got my header, oil filter and rear brake lever in the mail. Wire wheeled the header and heat shield and gave it some paint. Installed the oil filter. Sanded off the faded blue off the Renthal Bars and installed the new left lever.
ID:	236574Click image for larger version.
ID:	236584Click image for larger version.
ID:	236583Click image for larger version.
ID:	236582Click image for larger version.
ID:	236581Click image for larger version.
ID:	236580Click image for larger version.
ID:	236577Click image for larger version.
ID:	236576Click image for larger version.
ID:	236575Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Just got my shock covers in tonight. Gonna get those installed tomorrow and get the forks back on.
ID:	236586Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Installed the new shock covers, reinstalled the forks. Installed the bars back and put on the new grips. Used some old wet/dry vac tubing hose I saved when the vacuum broke, and it fit like a glove for the frame to airbox tube I was missing. Saved $45 there. Sweet!
ID:	236700Click image for larger version.
ID:	236701Click image for larger version.
ID:	236702Click image for larger version.
ID:	236703Click image for larger version.
ID:	236704Click image for larger version.
ID:	236705Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Used muratic acid to clean the tank of all rust. Put in a gallon and the rest water, let it soak for about an hour. Drain and put baking soda/water to deactivate the acid. Once dried, I used the Red Kote to seal it. I may do another seal just in case. Painted the tank white. Reinstalled the rear foot brake cable. Removed all the tires, pressure washed them, fixed what needed fixing and repainted one of them. Front and left rear wheels are aluminum and the right rear is steel, repainted the steel one with silver wheel paint. Diassembled the front brake as it was stuck. Brake shoes stuck to the drum. This happens when they are left in the rain and rust builds up in the puddle of water over time. All sorted now.
ID:	236818Click image for larger version.
ID:	236819Click image for larger version.
ID:	236820Click image for larger version.
ID:	236821Click image for larger version.
ID:	236822Click image for larger version.
ID:	236823Click image for larger version.
