Page 1 of 19 1 2 3 11 ... LastLast
Results 1 to 15 of 284
Thread: Time to see what all the Tecate hype is about?
    Las Vegas, NV.
    2,493
    As of yesterday, there's a new addition to the garage. This Tecate is fairly complete, but needs a ton of work. Unfortunately, I can't leave the R & Tecate alone for very long, as they just don't get along.
    Jan 2013
    minnesota
    5,911
    So you decided to get a high performance bike to go along with your 250r, that's xlnt, it should be fun!
    Looks like someones put a pipe on it so they might have gotten into the cylinder also ad if so, that could be good or it could be bad . Also check to see if the KIPS valve is operational or not.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    AND OWNER OF A TRI Z THAT ACTUALLY HAS A REAR SHOCK ON IT
    Arizona
    843
    Congratulations, the 2nd generation Tecate is a great machine and increasingly hard to find. Greg at Off Road Innovations can meet a lot of your Tecate needs. He makes some OEM replica parts that are no longer available from Kawasaki. Here's my 86.
ID:	239184Click image for larger version.
    Las Vegas, NV.
    2,493
    I thought it was a DG pipe with the badge removed, and after seeing christph's pics, I'm fairly certain that is what it is. Yes, supposedly it has been ported, and I do not believe the KIPS is working properly or possibly at all, as there is no punch to it. Once I dig into it, I will know for sure. Reading over the Tecate service manual, there doesn't appear to be any way to easily test the system for functionality.
    Thanks for the pics christph, nice Tecate!
    House Springs MO
    5,494
    Common problem when going from a 250r to a Tecate.
    Jan 2013
    minnesota
    5,911
    hmmm....I wonder if that might be because the Honda doesn't have a valve at all.
    House Springs MO
    5,494
    No kidding Barn?
    I was talking about the lack of punch. It's a common problem when you go from a 250r to a Tecate.
    Mexico
    9,018
    Remind us again how many Baja races that mighty Tecate won?
    It sucks to get old
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    I feel a disturbance in the force.
    What are you going to do about your 3WW handle? Red rider?
    Let the money and time pour into the new machine.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Las Vegas, NV.
    2,493
    Mine does. 3 valves to be exact.
    1 Reed valve & 2 exhaust valves.
    6 if you want to count the valve stems too.
    Jan 2013
    minnesota
    5,911
    Yes, that is a DG pipe.
    One reason I mentioned to check the valve system is because some people disable the actuator system then fix the valves so they are wide open all the time and this will kill the bottom end . If the drive gears are stripped send jeswinehart a pm, I think he may have them.
    Las Vegas, NV.
    2,493
    Quote Originally Posted by arlaunch View Post
    Going to the dark side have I?
    Jan 2013
    minnesota
    5,911
    Ok, so what does that sporty looking white fender belong to in the left side of the photo?
    Jan 2013
    minnesota
    5,911
    No, you have simply finally seen the light and the path to your salvation . Can I get Hallelujah brother!
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    [QUOTE=barnett468;1441228].
    That is the funniest post i have almost ever seen!
    Thank you for staying on here barnett468.
    Unlike 2 or 3 others i appreciate your posts. Especially when they are super duper funny!!
