Results 1 to 15 of 16
Thread: new to 3wheeling trike has transmission issues 84 125m
    Jun 2017
    earth
    11
    hi all just picked up my first trike and as usual joining my first group relating to my newest find lol...
    i picked up a 1984 125m and cant seem to get it into gear. when i bought it i was told second gear doesnt work but first and third are fine. since replacing the rear bearings for the axle I've come to realize i cant get it into gear at all... is there a tear down manual somewhere for opening the transmission up to look at the gears etc? is it hard to open? figured i would ask before blindly wrenching away and breaking something else lol
    Jul 2016
    Pennsylvania USA
    65
    Look online there’s a ton of part outs and very cheap service manuals
    ~Matt Gusciora
    Jun 2017
    earth
    11
    so your reply is look on google and get off this group? so welcoming lmao
    its a pretty simple question im looking for a answer too... how hard is it to open the transmission to look at the gears...
    Jun 2017
    earth
    11
    hopefully other members are a bit more helpful :/
    Jan 2017
    SD
    39
    Quote Originally Posted by rob3307 View Post
    Don't be like that, it won't go well.
    Alrighty. Let's try this again.
    Welcome.
    Service manuals are a very good resource. They include not only the exact procedures for inspection and repair, but also offer several tips and hints as to how to go about things as you use their information.
    http://www.oscarmayer.net/atc/manual...vicemanual.pdf
    6,811
    Very common problem with that model , most likely not a transmission problem , the shift drum stopper is either broken , loose or the boss that holds it to the case is broken , pull the right side clutch cover off and inspect , you will be looking at the top left side .
    Jul 2016
    Pennsylvania USA
    65
    Sorry lol that’s what I always have done I am a owner of 11 trikes and have done that for all manuals. I do not own that model so I was just suggesting
    ~Matt Gusciora
    Jan 2017
    SD
    39
    Sweet. Shortline10 knows the business on these mamma jamma's so i'd follow his lead if I had one. Post pics!!!!!!!
    Jun 2017
    earth
    11
    Getting acquainted with the old girl lol just stuck on flywheel till I can get a bolt to make a removal tool... I'm splitting her apart to look inside and am going to give it a overhaul
    Already made this for the damn clutch locknutClick image for larger version.
    Aug 2013
    Memphis, TN
    88
    Welcome Rob,
    Good job on the custom tool....I went through the same process you are experiencing now, a couple years back on my first 125m. Here's the link, maybe it will help.
    http://www.3wheelerworld.com/showthr...nd-85-125m-ATC
    I did get the manual at that time...it was very helpful, and in the case of my honda atc knowledge, I might say it was essential lol.
    Anyway, keep us posted on your progress....the 125 is a fun little trike.
    Dave
    Jun 2017
    earth
    11
    thanks for the link, it seems the gear(second main) was almost fully stripped, ill post pics shortly, anyone know where i can get a mainshaft second gear as well as a new chain sprocket? seems a few points are gone on the sprocket but i prob could still use it. also any idea where to get all new gaskets? crank case cylinder every seal for everything removed pretty much is garbage now lol
    Jun 2017
    earth
    11
ID:	244009Click image for larger version.
    Jun 2017
    earth
    11
    any ideas where one can get gears? not having much luck on my end locating much :/
    6,811
    I might have a whole bottom end , I can dig threw my motor pile tomorrow if that interest you ?
    Jun 2017
    earth
    11
    prob not going to be worth it after you figure shipping if your in florida lol
