I'm in the beginning stages of starting a purpose built flat track / tight track 250r and was hoping for any help or advice, starting with suspension. I found this video https://youtu.be/3A0RF87ly6E online of someone shortening some conventional bike forks...they look very similar to 250r forks and I thought this might be the way to approach shortening my forks. My plan was to remove the short 3" spring from '85 forks and adding a 3" spacer to the pipe, seat, below the rebound spring, as opposed to cutting a spring as shown in the video. Is this the correct way to go about this?
I already have a Durablue lowering link and considered using it to lower the rear end 3" as well(assuming I should subtract the same 3" to keep the rake the same?), but have also considered having my rear shock internally shortened because it needs to be serviced anyways....I'm just not sure if it would be worth extra expense as opposed to just using the lowering link.
I also want to throw in this tidbit of info regarding the rear end and rake...I'm planning to use a -1" (18.5" ctc) LSR swingarm, will this affect the amount I should lower the rear?
Any info you guys can add would be great, thanks!
