Results 1 to 15 of 16
Thread: Looking for a flanged sleeve
    Scootertrash's Avatar
    In the sticks
    4,638
    Looking for weldable steel flanged sleeves:
    Flanged on one end
    I.D.: 1 inch
    Sleeve wall thickness: 1/8 +/-
    Sleeve length: 1 1/2 - 2 inches
    Flange diameter: 2 inches +/-
    So far all I can find are flanged bushings or flanged bearings made out of stainless, bronze, oilite, etc.
    I could probably buy seamless steel tubing and raw steel washer and weld them up myself but purchasing premade ones would be much easier
    House Springs MO
    5,496
    Don't you have a lathe scooter?
    Connecticut
    1,605
    In the sticks
    4,638
    Sure do, I have a small Atlas lathe. Problem is I need a minimum of 8 of these and up to 24. Purchasing a prefabricated item would be far less time consuming.
    Last resort I'll buy some seamless steel tubing and raw steel washers and weld them up. I can weld the washer on for the flange while the bandsaw is cutting more tubing.
    House Springs MO
    5,496
    Gotcha, I thought you only needed one. That would be time consuming cutting the stock to length and machining.
    In the sticks
    4,638
    Quote Originally Posted by sledcrazyinCT View Post
    Thanks for the suggestion sledcrazy, but they're too big and bulky. I'll try to post some sort of pic or diagram later.
    Williamstown PA
    5,825
    I work in a machine shop. CNC and manual leath. send me a request at aaron@bondcaster.com Just give a drawing of your dimension and material you'd like. We can make them.
    Could you draw them with the intended application??
    Just curious, 2 heads are better than one...
    In the sticks
    4,638
    Kinda spendy to set-up and run a small batch of parts ain't it?
    In the sticks
    4,638
    I'll try to draw something up tomorrow.
    Basically I'm trying to mimic Polaris's Lock and Ride quick mount system for thier powersports accessories, cargo boxes to be exact. Problem is I have an older Can-Am.
    Most ATV cargo boxes come with a crappy U-bolt mounting system. I've heard good things about Polaris's quick mount set-up, but not so much on the Can-Am style.
    ETA: A better video on how the system works:
    https://youtu.be/4AzKATJy0f4
    The round holes you see in the plastic rack are for the cam lock mounting pieces. They look like this:
    I'm going to make my own "holes" and weld them to my Can-Am rack so I can have a quick mount setup.
    az
    2,022
    Google flanged pipe fittings. Lots of different pics pop up. Jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    In the sticks
    4,638
    Quote Originally Posted by Jim mac View Post
    My Google fu is pretty good. Typically, by the time I come to one of the forums I frequent asking for help, Google hasn't given me what need
    TTown, Alabama, United States
    845
    Have you checked McMaster Carr? I know they have a lot of odds and ends like that.
    Edit....seems like all they have is bearings.
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    There are bronze flat washers that can be used, it all depends 3the application...
    Just curious, trying to help with some things I've done for a very long time....
    D - Press fits into??
    F - Clearance fit to spin on??
    Sent from my SM-N960U using Tapatalk
    In the sticks
    4,638
    All of these dimensions are approximate, I haven't finalized my design yet. Just going off of the dimensions of easily obtainable materials. Everything needs to be weldable steel.
    A and B: Not determined yet, I haven't gotten that far in the design process. Waiting for the cam lock fittings to get here.
    C: Approx 1/8" +/-
    D:Approx 1-1/4"
    Hole will be drilled for a drop in fit, then the sleeve will be tack welded in 2 or 3 spots on the bottom of the rack around "D" and then on the top of the rack around "E"
    E:Approx 2"
    F:Approx 1"
    The fittings I posted above will be a slip to light friction fit, operating the cam lever compresses the rubber portion of the cam lock part and tightens it up in the bore.
    Here is a pic of the rear rack. I will either modify the existing oblong holes to fit the sleeves, or I will weld a piece of steel across the longer openings at the edge of the rack in four equally spaced locations and drill the holes for the sleeves there.
    ETA: Looks like I should have at least one of the cam lock devices today.
